AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 11-11-2007, 11:31 PM   #1 (permalink)
Thanks: Gave 16, Got 6
Harmony RF WIRELESS EXTENDER - How does it work?
I don't get it...
Does it emit RF signals for RF controlled devices - If so how can it be called an extender?
Does the RF relate to the communication link between the Harmony 1000 RC and the extender unit, which them emits IR codes again?
Sorry but I am confused about this...can anyone help?
AK
My photos at: http://www.pbase.com/photokhan
AlfaKhan is offline
Old 12-11-2007, 3:35 AM   #2 (permalink)
Thanks: Gave 0, Got 117
Re: Harmony RF WIRELESS EXTENDER - How does it work?
The second option.
The remote sends a command via RF to the extender, which converts the command back to IR and sends it to the components.
You can't directly control an RF device (no universal remote can) apart from those that use the "Z-Wave" protocol.
czzer is offline
AlfaKhan (12-11-2007)
Old 12-11-2007, 10:01 AM   #3 (permalink)
Thanks!
So, to further clarify it, although the Harmony 1000 can not control RF-controlled devices, it DOES have RF capability, at least to transmit the commands to the extender?
Is this correct?
AK
AlfaKhan is offline
Old 12-11-2007, 10:16 AM   #4 (permalink)
You got it.
czzer is offline
Old 12-11-2007, 10:46 AM   #5 (permalink)
JimBobVFR400's Avatar
Thanks: Gave 10, Got 104
exactly what he said.
Although going off topic it is actually possible to learn some RF commands.
I have successfully used the RF receiver bit of a powermid to receive the RF from the remote for a switched RF socket, convert to IR to be learned by my pronto and change this command on the pronto to transmit this command as RF. Worked a treat.
JimBobVFR400 is online now
extender, harmony, wireless, work
Refbacks are On
Thread Thread Starter Forum Replies Last Post
RF Extender for Harmony 885 1975jas Remote Controls 0 11-04-2007 10:04 AM
Harmony 895 RF Extender Rteyp Remote Controls 2 25-02-2007 5:36 PM
Harmony 895 RF extender dobbin Remote Controls 1 12-09-2006 7:20 AM
Wot Repeater/Extender for Harmony 655 mjb-av Remote Controls 2 08-06-2006 7:59 PM
Harmony 885 IR Extender Mr_Wistles Remote Controls 11 24-04-2006 6:37 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
