AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 07-11-2007, 10:14 PM   #1 (permalink)
Thanks: Gave 7, Got 1
Simple Question on Harmony 525 Before I Buy
Hi all,
After reading through some of the threads on here I'm thinking of buying a Harmony 525 remote (or at least asking for one for Christmas!)
I want it to control my Sharp LC32AD5E TV, Philips DVD Player and Sky+.
I'm just not sure if it will do what I want - on the TV, to select a different source you have to press the "input" button a number of times (e.g. 5 times to get to EXT5 which is my DVD player). Would the 525 support this? I've seen mention of "discrete codes" which I think means that there's a code that takes the TV straight to EXT5 but where would I be able to find out if these codes exist for my TV? I've already downloaded the Harmony software but it won't let me install it without a remote connected.
Thanks in advance.
finst3r is offline
Old 07-11-2007, 10:19 PM   #2 (permalink)
Abbeygoo's Avatar
Thanks: Gave 717, Got 714
Re: Simple Question on Harmony 525 Before I Buy
I've got the Harmony 885 and would presume it works in the same way.
When you set up the Harmony remote via the Logitech website you CAN program it to do exactly as you have described. So, when you press the 'watch TV' button on the remote, it will take you to the correct input for the activity you have described.
If it helps, when I press "watch TV" it turns my TV on to the right input (component) and when I press "play game" it turns the TV on to the right input again (RGB ext 1). You don't need to keep pressing the input button the remote does all that for you.
Hope that is clear!
Steve PSN : abbeygoo
Official AVF League Premiership Peterborough United
Official AVF World Cup MEXICO
"Fear can hold you prisoner, hope can set you free"
Abbeygoo is offline
finst3r (09-11-2007)
Old 07-11-2007, 10:24 PM   #3 (permalink)
Cheers,
Just so I can get my head around it, when you choose "play game" etc does it press "input" 3 times itself, or does it know how to go directly to the input source? I guess I'm wondering what would happen if it loses track of which input source the TV is on, or one of the "presses" doesn't get through to the TV (cat walks past etc!)
Also, is there somewhere I can check if my TV is supported?
Sorry if I'm asking daft questions!
Thanks again.
finst3r is offline
Old 07-11-2007, 11:11 PM   #4 (permalink)
Abbeygoo's Avatar
I would check the Logitech website if you're unsure on anything.
But, yes, as I understand it the Harmony knows how to turn to the correct input each time you turn on. When you program the remote via the website it asks you to confirm which input is used for each function and it simply turns to the correct input depending on which activity you select.
It would make sense to keep the remote pointed in the general direction of the appliances you are controlling ..... even if it doesn't work first time, the 'help' button on the remote is a remarkable piece of work!!
Abbeygoo is offline
Old 08-11-2007, 7:56 AM   #5 (permalink)
Cheers but I can't find much info about which TV's are supported (or much more information) on the Logitech website.
Does anybody know if Sharp TV's have the ability to have their input source selected directly?
Thanks.
finst3r is offline
Old 08-11-2007, 1:26 PM   #6 (permalink)
Thanks: Gave 25, Got 30
Originally Posted by finst3r View Post
Hi all,
Thanks in advance.
Yes, it will do this.
I have a 555, and you can pre programme it to go to certain inputs. For example, set up an activity for DVD. When seleceted it will power up the DVD player switch to the relevant input and power up TV, amp or whatever else you have programmed into that activity. This is all done from selecting one button.
You can also customise individual buttons, based on the piece of kit you want to operate.
It is a really good remote, well worth the money.
PD_BARBS is offline
finst3r (09-11-2007), tobyfield (14-11-2007)
Old 08-11-2007, 2:49 PM   #7 (permalink)
Thanks: Gave 8, Got 43
If the 525 is like the 885 (I presume it is) then when you select your devices (TV, dvd, etc...) before you create the activities (watch tv, watch dvd, etc...) during the device settings you tell it whether your tv changes input by either
a) a certain button for each input
or
b) press the input button a number of times to cycle through the input (as you do)
so yes it should work.
My advise is to get one, they are great - very easy to use for kids and wife regardless of how many devices you have, easy set-up via web-site, great customer support. We only use the harmony and hide the rest of the remotes.
Panasonic TH42PE50B TV :: Denon 2307 receiver :: Denon 1930 DVD :: KEF KHT3005 speakers :: Harmony 525 remote :: Wii :: Sky HD 500 GB :: PS3 320GB
sp_harris is offline
Old 09-11-2007, 6:15 PM   #8 (permalink)
Thanks everybody,
Is it possible to check the database online so that I can check my TV is supported (with direct input select)? I've seen mention of checking the logitech website in other posts but can't seem to find the harmony remote database...
Cheers.
finst3r is offline
Old 09-11-2007, 10:52 PM   #9 (permalink)
Thanks: Gave 0, Got 117
You can't access the database until you have a remote.
I added that TV to my account and it has discretes listed for InputExt1 thru InputExt6. Of course this isn't a guarantee they actually work, but it looks like you should be fine.
czzer is offline
Old 09-11-2007, 11:25 PM   #10 (permalink)
Thanks - good enough for me. I'll get it and see if it works - at least I'm fairly confident that it will work now.
Thanks again!
finst3r is offline
Old 10-11-2007, 4:56 PM   #11 (permalink)
Oily's Avatar
Thanks: Gave 27, Got 32
If you can't get it working how it should,just contact support,they're excellent,they spent about an hour on the phone(from Canada!)sorting out the problem selecting inputs on my LG.
Work is for people who don't know how to fish!!
My DIY AV rack http://www.avforums.com/forums/av-st...e-av-rack.html
Oily is offline
525, buy, harmony, question, simple
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Simple Harmony 885 device question docfeelgood Remote Controls 13 18-05-2007 5:59 AM
simple question ? DUVET Satellite TV 2 20-07-2006 8:39 AM
Simple question from a simple person ! novice@leeds LCD Televisions 1 30-01-2006 9:13 AM
simple question for a simple guy! papa_flump Plasma Televisions 6 11-08-2005 10:53 PM
Simple question from a simple member mandril DLP, LCD and D-ILA Projectors 14 27-06-2004 1:24 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
