AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 06-11-2007, 8:36 PM   #1 (permalink)
Thanks: Gave 4, Got 8
Possible purchase of an all in one remote - but which one?
I have been considering replacing all the different remotes in the living room with an all in one remote control, but I have no idea what I am looking for, which one is best etc etc etc, so I am coming to you all with a request of help
I have the following devices to be controlled by the one remote
Samsung PS42Q96HD
Humax PVR9200TB
Sanyo SX25 DVD player ( soon to be replaced with an as yet unknown player)
Philips mini Hifi unit (not sure of the model at the moment)
and if possible, an xbox 360 - dvd functions (this one may is a long shot)
I'm looking to spend max £50 but will stretch the budget for the right one
Your help is greatly appreciated.
Samsung PS42Q96HDX, Humax 9200T(B), Setanta Sports, Sky+, Xbox 360 Elite, Dell Inspiron 1501
lovethechang is offline
Old 06-11-2007, 9:05 PM   #2 (permalink)
Thanks: Gave 1, Got 0
Re: Possible purchase of an all in one remote - but which one?
The Logitech 525 will quite happily control all of that for you. Should have change from £50 too.
ingsy1981 is offline
Old 06-11-2007, 9:18 PM   #3 (permalink)
docsmith2k1's Avatar
Thanks: Gave 43, Got 12
Having worked my way through a number of universal remotes over the last few years, including models from marantz, philips, and all-in-one, I too can recommend the logitech remotes - easy to set up (as long as you have an internet connection) and very versatile. I have a number of esoteric devices which are controlled perfectly with the logitech.
Andy
Arcam AV9/P7, Arcam DV139, SIM2 HT380, M+K 150's, M+K THX350 Mk II. Canon 5D and a bunch of glass.
docsmith2k1 is offline
Old 06-11-2007, 10:09 PM   #4 (permalink)
having read another forum post regarding the harmony 525 I have been told it isnt as responsive as the humax remote when going through the menus? Can anyone confirm this?
How easy is it to map all of the main functions of the humax remote? How much time should I be looking at to get it up and running?
I also notice that this remote uses 4 AAA/AA batteries - how long will I get out of these as I have seen some responses saying I should only expect 2-3 weeks per set of batts
In any case I've also done a search and found this remote for £41.41 at ebuyer.com
purchase, remote
Refbacks are On
Thread Thread Starter Forum Replies Last Post
PC infrared receivers for use with sky remote - where to purchase? lightbulb Computer Systems 3 07-08-2006 1:11 PM
Where can i purchase Points in which to purchase pics and styles with? Batch Xbox 1 20-11-2005 12:28 AM
Pioneer VSA-AX10Ai-S Remote Control Purchase? Moosh Remote Controls 0 18-05-2005 10:08 AM
Advice required for website purchase and purchase of projector torimusic DLP, LCD and D-ILA Projectors 1 25-02-2004 12:07 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
