AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 06-11-2007, 7:01 PM   #1 (permalink)
Thanks: Gave 1, Got 0
New Remote Needed. Not Logitech!!!
Hi guys, I am looking for a new remote to replace the 5 or 6 I'm using now. I got a logitech 525 a couple of months back, but could it balls work with my TV (LG 42PC56). The main problem was that it would never switch to the right component. There were some other issues with the DVD but i was'nt to fussed about that.
So after many a time re-doing the settings and calling logitech, I decided that i was going to give up and stick with the 5 remotes.
That again has got really annoying.
Is there any other decent remotes that will do the job and not cost the earth???
Any advice is appreciated
ingsy1981 is offline
Old 06-11-2007, 7:53 PM   #2 (permalink)
Thanks: Gave 3, Got 23
Re: New Remote Needed. Not Logitech!!!
Try any of the All four one remotes (cheap) or URC remotes (my favourites -e.g. Mx-500,MX-700).
Cyril is offline
Old 06-11-2007, 7:59 PM   #3 (permalink)
Thanks, Ill have a look at those. Do they have a similar feature to the logitech in being able to turn 3-4 devices on at the same time?
Anymore?
Old 06-11-2007, 8:07 PM   #4 (permalink)
Thanks: Gave 21, Got 67
If your TV does not support discrete codes for on/off, source input etc then any remote will struggle to operate activities with any degree of success. It is not a problem with the remote but with the TV (or other sources) that do not support discrete codes. You can play around with creating sequences of commands to emulate discrete code operation - your TV may switch in from stanby by pressing a channel number rather than power toggle for example in which case use a number for "on" and a number followed by power toggle for "off" but this can lead still give problems occasionally. With that in mind you may be better to create very simple Activities and then make sure you have buttons for power & source toggle easily accessible so you can make the necessary adjustments without lots of fiddling. You could do this with your Harmony if you still have it by also making sure the relevent TV commands are included on the Activities screen.
neilball is offline
Old 06-11-2007, 8:07 PM   #5 (permalink)
Anybody know much about this?
http://www.amazon.co.uk/Philips-Pres...4379521&sr=1-6
Old 06-11-2007, 10:10 PM   #6 (permalink)
JimBobVFR400's Avatar
Thanks: Gave 10, Got 104
I've got one. The activities are a little restrictive (you can't change labels)
You scroll using the silver scrolly bit through devices then activities on the smaller screen above the main touch screen which can be a bit of a pain.
The touch screen itself can't be changed, you can learn on any button but not change the labels on them.
The remote itself looks well nice, very good quality although the silver scroll wheel isn't quite up to the standard of the rest.
I quite liked it but its nothing more than a fancy version of your boggo standard One4all remote. Still gets use in the bedroom. If you didn't get the Harmony to work right then you stand no chance with this particular philips.
Did you have a look in the forums on www.remotecentral.com for discreet codes for your TV. You can program these into your Harmony or other PC programmed remote if they are available
JimBobVFR400 is online now
Old 06-11-2007, 10:24 PM   #7 (permalink)
LG's TV's in general tend to have good support for discreet codes, I had a quick look on the discreet code hunter on RC and theres quite a lot there about discreet codes (nothing for your specific model but they often share remote codes between models)
If you still have the harmony give them a try
If you want the ultimate in customisation I would go for a 2nd hand (or new old stock) pronto. My pronto RU950 was really cheap on Ebay and is IMHO miles better (once setup properly) than anything Harmony do. If you can afford it the colour screen (RU980/990 or TSU7000/7500 USA models) are absolutely awesome but probably overkill for a lot of people.
Programming is either a pig or a pleasure depending on your point of view, its certainly challenging at first but I personally found the process very enjoyable.
Old 07-11-2007, 7:33 AM   #8 (permalink)
Thanks: Gave 5, Got 1
Uhhggg! That pronto RU950 one fugly Mother
Intenso is offline
Old 07-11-2007, 7:46 AM   #9 (permalink)
Anymore?
http://www.universalremote.com/produ...l.php?model=55
Can have macros to send 20 commands, so you can turn 20 devices on at the same time!
Cyril is offline
logitech, needed, remote
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Which Logitech Harmony Remote? mike543 Remote Controls 3 12-05-2007 8:45 PM
logitech harmony remote THERAAAVEN Remote Controls 2 28-10-2006 8:44 AM
For Sale: Logitech Harmony Remote 885 Advanced Universal Remote As New MerMan Archive : Completed Business and Expired Threads 16 13-02-2006 11:33 AM
FS: Sky + remote new & Nikon D100 battery FS: LOGITECH HARMONY 676 REMOTE chaka7862 Archive : Completed Business and Expired Threads 13 21-02-2005 8:56 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
