AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 06-11-2007, 4:29 PM   #1 (permalink)
Logitech Remotes and Coloured Buttons
Hi All,
I'm just in the process of selecting which logitech version of the harmony remote to purchase, and have been reading that the 1000 has problems with the coloured buttons needed for such thinkgs as teletext and more importantly Virgin V+ and Sky HD
I'm not worried about the cost, I just want the best remote, but on the 525 there are no coloured buttons as standard on the remote, but on the 555 and the 785 there are (that seems like a good thing to me), then they disappear again on the 885 and 895...
If you look at my signature and the equipment I have (I know it won't help me with the PS3), can somebody else with equipment like mine tell me which remote they have and which works..
As I'm a bit wary of now purchasing a remote without the coloured buttons...
Also as another quick question, as all the buttons on all the other remotes are different, how do you remember which buttons on your Harmony do what action, is this a memory exercise, or is it quite straight forward..
SONY KDL40W3000 - VIRGIN V+
PS3 (Blu-Ray, Gaming & Media Server)
ONKYO TX-SR605 - KEF 3005 SE (Eggs)
Swaggie is offline
Old 06-11-2007, 5:06 PM   #2 (permalink)
Thanks: Gave 0, Got 8
Re: Logitech Remotes and Coloured Buttons
Originally Posted by Swaggie View Post
Hi All,
The 895 does have the coloured buttons.
Tank
tankstage is offline
Old 06-11-2007, 6:04 PM   #3 (permalink)
Paulie-W's Avatar
Thanks: Gave 641, Got 341
I have the 525 & 885 and can confirm they both have coloured buttons. Sometimes the pic put up is the American version which doesn`t have the coloured buttons.
(((Flickr)))
Paulie-W is online now
Old 06-11-2007, 6:07 PM   #4 (permalink)
yep I'm looking at the logitech uk website, and there is no hint of a coloured button on some of the remotes....
so can I safely assume that all models above the 525 have coloured buttons ?
then I can just take my pick of them...
Swaggie is offline
Old 06-11-2007, 6:21 PM   #5 (permalink)
Paulie-W's Avatar
The uk ones do.
Clicky
Clicky 2
Of my two i much prefere the 885. Mainly for tactile reasons, and better (imo) layout of the buttons.
(((Flickr)))
Old 06-11-2007, 7:22 PM   #6 (permalink)
Thanks: Gave 34, Got 19
I've got a 525. Definately has coloured buttons. Have them all programed to go with my V+ & my 360.
50PZ70 - AX200 + 92in Beamax - HD-EP30 - 360 Elite - Sky HD - HTPC, E6600, 800GB, 4GB DDR, 8600GT + Blu-Ray Read/Write, Antec Fusion Case - XPS m1210, 12.1 , Core 2 T7200, 100GB, 2GB DDR, Go7400 - Logitech z-5400 - Thor 4-1 - Harmony 525 - 30GB Zen Vision-M - iPhone 3G
simonhipsey is offline
Old 06-11-2007, 7:46 PM   #7 (permalink)
Thanks: Gave 5, Got 1
I have the 525 and its a Winner!
The main fixed buttons on the remote are all labelled and reflect the buttons that you might normally use such as info, guide menu, exit etc. The LCD features any other functions that you might use and can be customised by the user.
The 525 is really very good value for money.
Intenso is offline
Old 07-11-2007, 11:42 AM   #8 (permalink)
Thanks: Gave 25, Got 30
I would also recommend the 555, a great remote that should work with all your kit, although the 525 is cheaper if it meets your needs.
PD_BARBS is offline
buttons, coloured, logitech, remotes
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Coloured buttons - Harmony 688? andyfr Remote Controls 0 21-09-2007 7:14 PM
Coloured buttons on MCE remote iendicott Windows Media Center Edition MCE 6 19-09-2006 11:34 AM
Coloured buttons on MCE remote martyn_wheeler Windows Media Center Edition MCE 2 12-06-2006 1:17 PM
525-coloured buttons? martin day Remote Controls 8 06-06-2006 5:38 PM
Coloured Buttons! Nicholas Gibbs Past Entries 2 21-10-2005 10:18 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
