Wee tip guys. When your other half tells you the batteries shes given you are new, don't believe a word she says & make sure to check them yourself first. DOH!!!! What a waste of time, nowt wrong with my remote. Also, another wee tip if you do suspect your remote is inoperative. Try some button pressing (with new batteries
) whilst viewing the IR emitter (bit at the front of the remote) through the camera on your mobile phone. This makes it possible to see whether it is emitting or not & may aid fault finding during a repair.
