AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 25-10-2007, 11:08 PM   #1 (permalink)
Thanks: Gave 1, Got 24
Recommend me a remote!
It will be controlling:-
Toshiba 32wlt66 lcd.
Cambridge audio 640R
Cambridge audio dvd89
Sky +
SO if anyone has a similar set up any advice/experiances of a remote to control all would be very gratefull.
Panasonic TH46-PZ85-Cambridge Audio 640R-Cambridge Audio Dvd89-Samsung BD-P1400-Sky+-SB3-Mordaunt-short 902i,304,Mission m71 rears,Gale 4070 sub-Qed x-tube+Qed to rears-Ixos hdmi-Cambridge Audio Analogues-Monster co-ax-Monster Scart.
AV Monkey is offline
Old 26-10-2007, 1:36 PM   #2 (permalink)
Thanks: Gave 25, Got 30
Re: Recommend me a remote!
Sky +
Logitech 555, is reasonable priced, and able to handle anything I throw at it. (TEAC Amp, Rapsody N35 media player, phillips DVD, Wii, Sky+ box) Although I don't have the Cambridge audio stuff. it works well with my WLT66
PD_BARBS is offline
Old 26-10-2007, 1:37 PM   #3 (permalink)
hunts1uk's Avatar
Thanks: Gave 83, Got 467
Logitech 885 for me,great remote.Whats your budget?
Fujitsu P50XHA58EB Onkyo 606 Mission E34 Mission E32 Centre Mission E3C SVS PB10
Elite 360 Wii PS3 1m Dish Motorised Dreambox 800.
hunts1uk is offline
Old 27-10-2007, 4:09 PM   #4 (permalink)
Cheap as possible. I dont want to spend £150 say if i dont need to. How flexible are these all in one's? will they control the amp as far as Switching to dolby digital and prologic setting effectively taking over from the pro-logic and dd/dts buttons on the amp remote.
Old 29-10-2007, 1:19 PM   #5 (permalink)
Cynar's Avatar
Thanks: Gave 3, Got 144
Harmony 525. Electronic bargain of a lifetime at £43.
Panasonic TH50PX60, Humax PVR9300, Apple TV, PopcornHour NMT, Cambridge Audio 640R, Quad 21L2, Quad L2 Centre, ORB Audio Mod1 rears, Quad Lite Sub, BFD, Harmony 885.
Cynar is offline
Old 29-10-2007, 1:45 PM   #6 (permalink)
Thanks: Gave 5, Got 362
I've been told harmony remotes lock up frequently by a harmony dealer, is this true?
Last time I tried the online configuration I didn't like it at all, didn't just plonk picture of the remote so you just drag and drop IR codes to buttons of your choice...wizards telling you what do you want to do etc etc. Have harmony improved it? The MX Editor is far easier to use.
badbob is offline
Old 30-10-2007, 2:46 PM   #7 (permalink)
Cynar's Avatar
I've had 2 and neither has ever locked up.
I've never used MX Editor but find the Harmony software a doddle.
It seemed a bit strange after being used to Prontoedit but I think it's just what you get used to.
Cynar is offline
Old 30-10-2007, 3:10 PM   #8 (permalink)
Can the 525 do these functions or just basic functions i.e volume control and channel changing on sky+box/tv?
Old 30-10-2007, 3:30 PM   #9 (permalink)
hunts1uk's Avatar
It will do that and more without a problem mate,Set up right it will do everything your remote will do.
hunts1uk is offline
Old 31-10-2007, 6:30 AM   #10 (permalink)
Thanks: Gave 16, Got 19
Try Ebay - I bought my (unused) Harmony 555 for £35 as I also wasn't sure if it was worth spending a load of money on a remote. However, now that it is set up, it is well worth what I paid, and more, although I doubt whether I could ever justify spending £100+ on a remote.
The Logitech set up web-site can be a chore, and you have to be prepared to spend quite a time (several hours!) with it connected to your PC, with lots of remote updating while fine-tuning the details, but once you get your head round it it is fairly logical.
Colin
Panasonic TH-42PX70, Onkyo TX-SR605, Toshiba HDEP30, Canton Movie 150QX speaker system, Sky HD.
wing.rider is offline
Old 31-10-2007, 3:03 PM   #11 (permalink)
Thanks for all your advice guys.
Old 01-11-2007, 6:08 PM   #12 (permalink)
Thanks: Gave 8, Got 11
Originally Posted by wing.rider View Post
Try Ebay - I bought my (unused) Harmony 555 for £35 as ...
That was a very good price. You've been lucky.
IMO, some ebay bidders are mad. I've been keeping an eye on ebay for a 525 for a while. Maybe I am cheap but they go for far more than what I am willing to pay for either a second hand with no warranty or to take the risk of buying a so-called "unused but just opened once" from some unknown source with no protection if the item would prove faulty. For example, a 525 went last week for £41 plus £4 postage! Wake up, amazon sells then new and delivered for £44. It's not as if it was an obscure retailer that noone has heard of. I've got in my ended watch list 525s that went for 32, 36, 35 all not including a 4 to 7 postage. This one is still running and has already reached £36 + postage http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260174413368
So yeah, maybe I am cheap but IMO the hassle and risk of ebay is not worth saving £4.
That said, ebay is great for more expensive AV equipment like the Totem Model 1 I got a few years ago for about £400. Yes, they have spike marks underneath but nothing else and they sure can sign :-)
Yan
yant is offline
Old 03-11-2007, 11:10 AM   #13 (permalink)
Just ordered a 525. £43 delivered amazon.
Old 03-11-2007, 3:12 PM   #14 (permalink)
Thanks: Gave 5, Got 1
I just picked up a 525 from Comet at £50. I didn't feel a saving of £6 was worth the agro of waiting for the postie!
Now that I've got the 525 set up I'm very impressed.
One touch of a button and my PV500 plasma turns on, switches to Component (no matter what the last input setting was), turns on the Tosh DVD and then opens the tray
Same for my Cable and Sat boxes.
The software took a bit of sussing out but now that I have its staright forward.
The remote itself is fine, maybe the finnish could be of a higher quality but I would expect it to cost much more then. Having said that the finnish is better than all my other remotes bar the PV500 which is top notch.
I would not hestitate to recomend the 525.
Intenso is offline
Old 03-11-2007, 3:20 PM   #15 (permalink)
Thanks: Gave 34, Got 19
I know it's all been said already but I have to give another vote for the 525... For the price it is by far my best thing I ever bought AV wise. Such a convenience.
Plan on keeping it for quite a while until I upgrade to an 895 which will be purely for when I wall-mount and move my gear out of line of sight and will need RF as opposed to purely IR.
50PZ70 - AX200 + 92in Beamax - HD-EP30 - 360 Elite - Sky HD - HTPC, E6600, 800GB, 4GB DDR, 8600GT + Blu-Ray Read/Write, Antec Fusion Case - XPS m1210, 12.1 , Core 2 T7200, 100GB, 2GB DDR, Go7400 - Logitech z-5400 - Thor 4-1 - Harmony 525 - 30GB Zen Vision-M - iPhone 3G
simonhipsey is offline
recommend, remote
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
