Hi, What Pronto do you use?
I seem to remember mu RU950 had a setup where you went to a certain page in the settings and could point the remote and it would search until it turned the item on/off an then you could see which codes built in were compatible!
Found this in the RU950 manual Searching the Brand and Code Set for your device
1 Press the left hard button below the touch screen for
3 seconds.
The Tools menu appears.
2 Tap Brand in the Tools Menu.
The ‘Brand Tool’ screen appears.
3 Tap in the ‘Brand Tool’ screen.
The Device Overview appears.
4 In the Device Overview, tap the Device for which you want to define
the brand.
5 Tap in the ‘Brand Tool’ screen.
The ‘Brands’ screen appears.
Searching the brand
1 Tap in the ‘Brands’ screen.
The ‘Searching the Brand’ screen appears.
2 Tap and point Pronto at the device.
The ‘Searching’ screen appears. Pronto searches through the list of brands, by
sending out an IR code for each brand.
3 When the device for which you are defining the brand, responds to the
IR code, tap in the ‘Searching’ screen.
The ‘Installing the Brand’ screen appears.
4 To install the brand and code set, follow the instructions described in
“Installing the brand” on page 17.
Stoobie
