Logitech Harmony One - Part Six
| Thread Closed |
| | #181 |
| Moderator | |
| Advert Log in or sign up to remove |
| | #182 |
| Senior Member | |
| | #183 |
| Member | |
| | #184 |
| Moderator | |
| | #185 |
| Member | |
| | #186 |
| Moderator | |
| | #187 |
| Prominent Member | Last edited by a l e x; 05-01-2012 at 11:33 PM. |
| | #188 |
| Senior Member | |
| | #189 |
| Moderator | |
| | #190 |
| Illustrious Mumbler | |
| | #191 |
| Senior Member | |
| | #192 |
| | #193 |
| Senior Member | |
| | #194 |
| Moderator | |
| | #195 |
| Senior Member | |
| | #196 |
| Moderator | |
| | #197 |
| Senior Member | Last edited by logiciel; 06-01-2012 at 7:36 PM. |
| | #198 |
| Moderator | |
| | #199 |
| New Member | Problems with Harmony One |
| | #200 |
| Senior Member | |
| | #201 |
| Moderator | |
| | #202 |
| New Member | |
| | #203 |
| New Member | |
| | #204 |
| Moderator | |
| | #205 |
| New Member | |
| | #206 |
| Moderator | |
| | #207 |
| New Member | |
| | #208 |
| Moderator | |
| | #209 |
| New Member | Last edited by logiciel; 08-01-2012 at 11:17 PM. |
| | #210 |
| Moderator | Last edited by logiciel; 08-01-2012 at 11:25 PM. |
| Thread Closed |
It's meant to be used only at the end of a viewing session. With the original remote you do of course have to turn off the TV and the amplifier separately, but the Harmony does that with the single press of the Off button, together with any other device that is still on after it's been turned on by an activity and left on. When you start an activity all its devices get turned on - if they're not already on - in rapid succession separated only by the Inter-Device delays, so there's not much you can do about that. The answer to the problem of the TV going to the wrong input setting depends on the answer to my first question in post #194 - and that answer is?
LinkBack URL
About LinkBacks
