IR programmable Keypad...
Old 19-11-2009, 9:14 PM   #1
1,392, Level: 8
Points: 1,392, Level: 8 Points: 1,392, Level: 8 Points: 1,392, Level: 8
Cool IR programmable Keypad...
Yo i'm after a we'll priced on wall key pad that can be programmed/loaded with hex codes to control any IR controllable device. I can only seam to find one's that require a central hub/control amp to function. I just want a basic keypad that controls a 4 way slave amp to provide music to different rooms...is this too difficult!!! Any help is appreciated, thanks in advance.
Old 20-11-2009, 12:01 AM   #2
makitamark's Avatar
3,322, Level: 13
Points: 3,322, Level: 13 Points: 3,322, Level: 13 Points: 3,322, Level: 13
Thanks: Gave 0, Got 21
Much, much too vague.
Do you want one keypad or a keypad for every room?
Do you need the amplification or do you already have that?
How many rooms?
Give us some idea of budget.
A simple keypad with IR out is easy, but is that what you require?
Old 20-11-2009, 1:12 AM   #3
1,392, Level: 8
more info...
Sorry makitamark...here's some more info
I basically want 3 keypads for various zones. I have amplification in the form of 'Onkyo TXSR803 zone 2' for one zone, and a TXSR503 which provides the 2 other zones (main output and zone two output from 503). Each keypad will have control over its corresponding amp for that zone, i.e bathroom will be 'txsr503 zone 2 output' and that keypad will be loaded with all the HEX codes to control for 'txsr503 zone 2'. Alll the keypads out there seam to require syncing with an expensive multiroom amp. Hope this helps...appreciate the advice in advance..thanks
Old 20-11-2009, 8:30 AM   #4
makitamark's Avatar
3,322, Level: 13
Thankyou for the clarification, you forgot about 'budget' however.
This is an excellent product and incredibly flexible.
Universal Remote Control Model KP-900
Old 21-11-2009, 4:45 AM   #5
1,392, Level: 8
Thanks!
Hey this keypad looks nice! A little on the expensive side and i don't require wireless but it's very appealing! Cheers for the help
Old 21-11-2009, 9:56 AM   #6
makitamark's Avatar
3,322, Level: 13
This should be a little more to your liking then...
Xantech.com
Old 22-11-2009, 5:49 PM   #7
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
There are a few options but you need to keep an a firm idea on how it is going to work there are some really simple keypads if you only want 4/8 commands on/off volume+ volume- etc but if you wnat more your better off looking at a basic 4 zone multiroom system.
Powered by
 Latest popular product prices
Venom Wii Remote Silicon Glove Twin
1 price
 £7.98 Click to show/hide the offers
Startech Adapter Kit For 2.5" Hd...
1 price
 £10.78 Click to show/hide the offers
John Lewis 2-Way Remote Control
1 price
 £13.00 Click to show/hide the offers
NIKON ML-L3 Wireless Remote Control
1 price
 £13.99 Click to show/hide the offers
Apple Remote
1 price
 £19.50 Click to show/hide the offers
Lindy 3 Port Hdmi Switch With Re...
1 price
 £20.38 Click to show/hide the offers
SKY TELEVISION SKY150
1 price
 £29.09 Click to show/hide the offers
Microsoft Xbox 360 Media Remote ...
1 price
 £22.95 Click to show/hide the offers
 Updated February 12th at 11:30pm. Prices include delivery.
