Setting up Harmony one with lava lvm 601 electric wall Bracket
Old 12-11-2009, 11:58 PM   #1
2,252, Level: 11
Points: 2,252, Level: 11 Points: 2,252, Level: 11 Points: 2,252, Level: 11
What ever I do cant seem to get the harmony to learn the IR signal from the original remote ,been on to logitech they have tried to help ,any one on here have any ideas please ,when i point the remotes at each other during setup the harmony receives the IR signal ,how can i tell if the harmony is sending out the right signal to the wall mount ............. Rashers
Old 13-11-2009, 12:13 AM   #2
makitamark's Avatar
3,322, Level: 13
Points: 3,322, Level: 13 Points: 3,322, Level: 13 Points: 3,322, Level: 13
Thanks: Gave 0, Got 21
Re: Setting up Harmony one with lava lvm 601 electric wall Bracket
The original remote that comes with the Lava bracket emits an unknown IR protocol, thus far I have not been able to identify it, maybe this is why the Harmony can't learn it.
The bracket itself however is able to learn codes from any other remote, the learning procedure involves flicking the switch on the module on the bracket and is explained in the manual.
Old 13-11-2009, 12:30 AM   #3
2,252, Level: 11
At the moment the harmony is set up for In and Out Movenent of the lava , i have tried getting the receiver of the lava to accept the Ir signal from the harmony but it just never sees it ,I dont know how an Ir sgnal works , can the Harmony send Ir signals at different frequencies or is this not how it works ...............Cheers Rashers
Old 13-11-2009, 12:47 AM   #4
makitamark's Avatar
3,322, Level: 13
Try to get the bracket to respond to another remote perhaps to your DVD remote. Read the lava manual as it explains how to get the bracket to respond to ANY IR code. If you can get this to work then simply use any command in the Harmony and teach these to the bracket.
Old 13-11-2009, 1:32 AM   #5
70,204, Level: 64
Points: 70,204, Level: 64 Points: 70,204, Level: 64 Points: 70,204, Level: 64
Activity: 99.8%
Activity: 99.8% Activity: 99.8% Activity: 99.8%
Thanks: Gave 1,258, Got 3,020
Award-Showcase
You might find it easier to set up a device you don't have and use its commands for the actual device to recognise.
Old 16-12-2009, 12:46 PM   #6
1,554, Level: 9
Points: 1,554, Level: 9 Points: 1,554, Level: 9 Points: 1,554, Level: 9
Thanks: Gave 10, Got 26
Harmony 1000
I setup my 1000 by learning the signals from the lava remote. In and out works fine, no problems.
Try varying the distance from the harmony to the lava remote when learning the signal, this can have an affect.
Similarly have you tried moving closer to the Lava IR signal receiver to see if this is possibly a distance related issue?
The Lava control box should flash when it is receiving a signal.
HTH...
Old 17-12-2009, 10:05 PM   #7
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
I have it working fine the lava uses a standard IR codeset but best idea is create the device properly and learn all the commands you need (power on /off and adjust in and out) and delete the randomn ones then set the cams on the bracket
Old 24-02-2010, 10:38 PM   #8
2,252, Level: 11
Only need in and out ,still carnt get this bracket to work with remote , I have input the commands onto the harmony and i can see it sending a signal ,with the lava in learn mode the led stays red is there something else i need to do to the harmony so it sends a recognizable signal to the lava, I have IR light switches and have no problem programming the remote and switches to work as I want Any help would be appreciated ..............Rashers
Old 24-02-2010, 10:54 PM   #9
70,204, Level: 64
Activity: 99.8%
Award-Showcase
Use the Custom mode for "learning" and learn each time to a renamed MyNewCommand.
Powered by
 Latest popular product prices
Venom Wii Remote Silicon Glove Twin
1 price
 £7.98 Click to show/hide the offers
Startech Adapter Kit For 2.5" Hd...
1 price
 £10.78 Click to show/hide the offers
John Lewis 2-Way Remote Control
1 price
 £13.00 Click to show/hide the offers
Sony PlayStation®3 Blu-ray Disc ...
1 price
 £14.88 Click to show/hide the offers
Apple Remote
1 price
 £19.50 Click to show/hide the offers
Lindy 3 Port Hdmi Switch With Re...
1 price
 £20.38 Click to show/hide the offers
SKY TELEVISION SKY150
1 price
 £29.09 Click to show/hide the offers
Microsoft Xbox 360 Media Remote ...
1 price
 £22.95 Click to show/hide the offers
 Updated February 13th at 9:30pm. Prices include delivery.
