Hi there, hope someone can help with this.
I'm using a harmony one through a mac mini and Onkyo 606 as a media center with XBMC. I have 2 problems I can't solve.
The remote isn't using the amp for volume it's being adjusted in XBMC. Adding a mac mini as a device doesn't let you control volume from the amp, it acts like an Apple remote (which I've lost
. I read a post that suggested going into customize buttons and changing the volume up and down to the amp. Doesn't work for me help! If the remote looses connection with the mac then it adjusts volume through the amp but of course looses control of XBMC.
next and possibly connected....
I have to unpair my harmony remote every time I switch the media center back on ie it looses connection. When I go to my mac securities tab to unpair the remote I only have a pair option to chose, not unpair. I have been unpairing the remote through the devices menu which works, I just have to do it every single time- bit of a nussance.
Any help would be very gratefully recieved- I'm totally stumped!!
Thanks!!
