HellraiserUK
Established Member
- Joined
- Nov 13, 2005
- Messages
- 229
- Reaction score
- 10
- Points
- 71
Have a Sagem HD-D50 G4(T)(2) set, and it suffers from the annoying issue where HDMI sources drop out for no reason - after browsing a few French forums, it appears this is fixed in the new firmware. At the moment I am running the following:-
Application HD-D45BC1 18
MCS 11
Formatter 6
Teletexte SUB V2.21
CW index delay 33
(In case you're interested, to access this info on your set press tvmenu then go to install, sources, config and then enter 3698.
Anyway, I am on the 18 firmware and the 20 firmware fixes this, but as Sagem no longer provide support in the UK, who do I go to to get the firmware?
Please help!
Hellraiser............>
MCS 11
Formatter 6
Teletexte SUB V2.21
CW index delay 33
Please help!
