Originally Posted by abergele Is it possible to record by time on the Humax Foxsat HDR (e.g, from 1pm - 4pm) so as to encompass several programs or do you have to go to "Table" and record each one individually??
Thanks. |
Assuming this unit has timers like most other units, and there is no reason to think it will not, then probably the easiest way is to input the first programme from the guide in the usual way - which establishes all the parameters in the timer screen of channel / date and time etc.... and then simply extend the end time.
To achieve that goto the Schedule screen which displays the list of timers programmed [ assuming this is like the Foxsat HD unit then to get there press Guide then Yellow button]
In the schedule screen, select the programme you have just input.
Select the end-time, and input a new end-time using the numeric buttons.
Select OK and Press OK.
