Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Entertainment Players and Recorders > PVRs and VCRs
Latest popular product pricesPowered by
Humax PVR9300T DVB-T Twin Tuner 320GB
Humax FOXSAT-HDR DVB-S/DVB-S2 Twin Tuner 320GB
Humax PVR9150T DVB-T Twin Tuner 160GB
Thomson DTI 6021 DVB-T Twin Tuner 250GB
Humax FOXSAT-HDR DVB-S/DVB-S2 Twin Tu...
Sagem DTR 94250 DVB-T Twin Tuner 250GB
Sharp TUTV322H DVB-T Twin Tuner 320GB
TechniSat Digicorder HD S2 DVB-S 160GB
TVonics DTR-Z500 DVB-T Twin Tuner 250GB
TechniSat DigiCorder HD K2 DVB-C Twin...
Ferguson F20500DTR DVB-T Twin Tuner 5...
 More...Prices updated March 21st at 4:30am and include delivery.
Thread Thread Starter Forum Replies Last Post
Wharfedale 160GB PVR from Argos - Q &A Ingsy PVRs and VCRs 90 23-04-2009 12:37 AM
asda' onn hdmi dvd player kylieboi DVD Players 156 11-03-2009 9:06 PM
Foxsat HD PVR : What does HD > symbol mean? lohr500 Freesat 3 11-03-2009 8:28 PM
Old 12-03-2009, 3:32 PM   #1 (permalink)
Thanks: Gave 11, Got 18
Asda pvr 801/802
Just been into the store in Sheffield and picked up the 801 and 802 for a fiver each I couldn't leave them, kids will be chuffed
Downside:
No Box
No Remotes
No Instructions
So where can I get replacement remotes and instructions??
Any help muchly appreciated
db
dbeevers is offline   Reply With Quote
Old 13-03-2009, 12:17 AM   #2 (permalink)
Thanks: Gave 4, Got 128
Re: Asda pvr 801/802
Originally Posted by dbeevers View Post
Downside:
No Box
No Remotes
No Instructions
db
Are these the Onn branded PVRs. Does the top of the unit look like the ones in this PVR image? Pay particular attention to the pattern of ventilation holes on the top of the unit i.e. the smaller width block of holes at the front and a wider block at the back. Ignore the front panel detail. Is there some identification on the Box with the software version and or hardware version, date of manufacture etc.
If it fits the description above then it is probably a Vestel PVR and if you have more detail it should be possible to suggest a source for the most appropriate manual and Remote Control.
Colin
creddish is offline   Reply With Quote
Old 13-03-2009, 12:57 PM   #3 (permalink)
There's no branding at all on the front of the units.
On the rear it says:
Asda LEPVR0801
Asda LEPVR0802
No soft or hardware version and manufacturing date.
I've uploaded some images of the 802
db
Asda pvr 801/802-dsc01038.jpg   Asda pvr 801/802-dsc01037.jpg
Old 13-03-2009, 3:55 PM   #4 (permalink)
Now found the remotes
so just need a manual
Old 13-03-2009, 10:09 PM   #5 (permalink)
Asda LEPVR0801
Asda LEPVR0802
db
Those images are not of a Vestel PVR. I can't remember the actual manufacturer but they were I think sold under the Yamada brand name i.e. as on the link here. I think Umax may be the manufacturer or maybe a distributor.
The website here may be of help. No sign of a Manual on there though.
There is a thread on what seems to be your unit here.
Colin
dbeevers (13-03-2009)
Old 13-03-2009, 11:25 PM   #6 (permalink)
Thanks for that.
I found a manual for a different brand (Akura AMTDT3502) apart from the HD cover being on the bottom of mine they look the same.
So £38 for 2 pvrs, 1 80 gig and other 160 gig me thanks I got a bargin (if they work)
ta for looking
db
Old 14-03-2009, 12:41 AM   #7 (permalink)
Thanks for that.
ta for looking
db
Yes I've got the Manual for the Akura AMTDT3502 and as you say it appears to be the same as yours. Akura do provide a manual on the link here.
Colin
dbeevers (14-03-2009)
asda, pvr
Copyright © 2000-2010 M2N E. & O. E.
