Humax foxsat recording
Old 10-03-2009, 11:41 AM   #1
1,839, Level: 9
Points: 1,839, Level: 9 Points: 1,839, Level: 9 Points: 1,839, Level: 9
I have a Humax Foxsat PVR with twin cables installed properly - I think. It shows two signals as far as I can tell. We can pause and play live etc and record programmes, but as soon as you start a recording it drastically reduces the normal channels that you can watch. For example I could record BBC3 but not be able to watch BB1 at the same time altough it would allow me to watch BBC2 etc.
I have been through all set ups and can't find a reason or reference. It was like that to start with and we contacted the installers and they came and fitted the second cable but I believe it's just the same now.
Any ideas?
Old 10-03-2009, 12:03 PM   #2
28,189, Level: 40
Points: 28,189, Level: 40 Points: 28,189, Level: 40 Points: 28,189, Level: 40
Activity: 95.3%
Activity: 95.3% Activity: 95.3% Activity: 95.3%
Thanks: Gave 39, Got 2,263
Re: Humax foxsat recording
Any ideas?
Did you do a factory reset after installing the second cable, if not that's the cause of your problem. If you do a factory reset the stb should report 2 cables found. Before you do this check that the second cable has not been fitted to tuner 1 out rather than tuner 2 in. If so correct this before the reset
Old 10-03-2009, 1:05 PM   #3
1,839, Level: 9
Thanks .The reset seems to have worked. The installers mustn't have done it.
Powered by
 Latest popular product prices
Sagemcom UK DTR 67250T ECO DVB-T...
2 prices from
 £99.97 Click to show/hide the offers
2 prices from
Logik L250STB11 DVB-T Twin Tuner...
3 prices from
 £109.99 Click to show/hide the offers
3 prices from
Goodmans GBD123DTR DVB-T 320GB
1 price
 £114.39 Click to show/hide the offers
1 price
Sagemcom UK DTR 67320T DVB-T Twi...
3 prices from
 £119.60 Click to show/hide the offers
3 prices from
 Updated February 12th at 3:30pm. Prices include delivery.
