Originally Posted by creddish Do you mean deleting individual Freeview Channels i.e. those listed on the EPG? If so I don't believe this will necessarily cure the problem. As I understand it the problem is caused by receiving signals from different transmitters so that can only be cured by ensuring that all MUX's are from the same transmitter.
I agree it necessary to clear existing MUX's before Manual scanning.
Colin |
Hi Colin
I don't actually know what I mean
... because I've not looked up the specifics of this particular machine, or how it handles tuning issues .. also I'm not sure whose, [or what ] problem is being addressed here.
If going back to the OP... then loss of a mux [ or its data ] is not likely to be cured by a rescan as the loss is more likely due to an aerial issue or transmitter on reduced power... in which case, a rescan can thereafter just make it impossible to receive that channel, because the channel placeholder will be lost.. so scanning under those circumstances is the wrong thing to do.
But so far I don't know what Dave I may or may not have done.
I gather it is not the channels that are missing - just a guide not populating .. so really it cannot be a mux issue ... unless the station he happened to be tuned to was 'iffy'.
It would probably be cured by either tuning to a BBC channel or one of the channels he was wishing to populate.
