Originally Posted by jdlegs Hi all
Does anyone know if its possible to change the RF output frequency on the Pioneer DVR 550-HX?
It might be interfering with my Freeview reception as I loose channels on both the DVR and the TV when I switch on the DVR... This only started happening about a month ago though so i'm getting the aerial checked too.
Thanks for your help! |
It has to be possible otherwise the box would be unusable in some areas. Without the manual can't say how but a troll through the installation menu should find the option.Most are set to channel 36 by default which screws up anybody who get Channel 5 analogue (always on uhf channel 35). you could try splitting the signal before the DVR rather than using the rf loop through.
