Originally Posted by beakybeak By my mistake... I've deleted/format all of my recording....
Can I recover them?
PS Oh, the machine is Humax PVR9200T |
I've not used it but HumaxRW software might be able to recover them but it requires the HDD be connected directly to a PC (you will need to open the Humax and either connect the HDD to a USB/IDE widget, or remove the HDD and connect it to a spare IDE interface inside the PC - if you've a laptop the USB/IDE is the only way). Oh and obviously don't record anything else until this is resolved as that will overwrite the lost recordings.
Member xyz321 on hummy.org is the guru to ask if you get stuck/need nore info.
