Can I Still Buy A VCR ??
Old 29-11-2008, 5:43 PM   #1
Conspicuous Member
panman40's Avatar
17,625, Level: 32
Points: 17,625, Level: 32 Points: 17,625, Level: 32 Points: 17,625, Level: 32
Activity: 59.8%
Activity: 59.8% Activity: 59.8% Activity: 59.8%
Thanks: Gave 2,006, Got 1,328
, Can I still buy a reasonable quality VCR from somewhere??, I dont really want a DVD/VCR Combo.
If somebody can point me in the right direction I would be grateful!!!,
Martin.
Old 29-11-2008, 7:27 PM   #2
3,631, Level: 14
Points: 3,631, Level: 14 Points: 3,631, Level: 14 Points: 3,631, Level: 14
Thanks: Gave 20, Got 1
Re: Can I Still Buy A VCR ??
They do appear on e-bay, quite often hi-spec models, too.
& freecycle!!
VB
Old 30-11-2008, 11:19 PM   #3
2,793, Level: 12
Points: 2,793, Level: 12 Points: 2,793, Level: 12 Points: 2,793, Level: 12
Thanks: Gave 3, Got 3
Whilst shopping in Morrisons, The Gyle, Edinburgh the other day I noticed they had an LG VCR for £49-99. It caught my eye because it is unusual to see stand alone VCR's on sale these days.
Not sure where you're based but if you have a Morrisons "large" store near you might be worth a look if they have an electrical section.
Old 01-12-2008, 3:18 AM   #4
2,376, Level: 11
Points: 2,376, Level: 11 Points: 2,376, Level: 11 Points: 2,376, Level: 11
Thanks: Gave 5, Got 4
Depends on the VCR you want, a lot of Professional Series VCRs (Progressive scan, Joggers, 4 head hi-fi....*mumbles off) are floating around in the low end TV-Production market, but other than those I'd look at my local pawn shop or e-bay.
Word to the wise- if you go to a pawn shop, tell them to hook up the VCR and have it play for 15 minutes before buying it. Just to make sure it works correctly.
Not really sure if you have pawn shops in Europe.
Old 02-12-2008, 8:27 AM   #5
2,745, Level: 12
Points: 2,745, Level: 12 Points: 2,745, Level: 12 Points: 2,745, Level: 12
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 12, Got 21
Last time I looked Argos still had one (LG?) in their catalogue...
Old 02-12-2008, 10:15 AM   #6
Growlerman
Posts: n/a
Argos do list three VCR's in their catalogue. There is a mono 2 speed Funai vcr, Nicam 6 head Funai vcr and a LG nicam video. Prices were £35, £45 and £60.
Asda did do two machines, a basic mono and a nicam stereo but I haven't seen them recently.
Hitchens store (Fleetwood) did have mono machines for £17 a while back.
Other than this it's Ebay, pawn shops or large charity shops as round here we have a charity called furniture finders and a hospice store that sell donated Tv's, VCR's as well as furniture.
Old 02-12-2008, 11:54 AM   #7
Conspicuous Member
panman40's Avatar
17,625, Level: 32
Activity: 59.8%
Many thasnks for all the help,
Cheers.
Old 02-12-2008, 5:14 PM   #8
3,907, Level: 14
Points: 3,907, Level: 14 Points: 3,907, Level: 14 Points: 3,907, Level: 14
Smile Re: Can I Still Buy A VCR ??
Richer Sounds shops nationwide stock the Philips VR550 Hi-Fi Nicam model (which also plays NTSC tapes) for £49.95
Old 04-12-2008, 10:39 PM   #9
phoenicks_uk
Posts: n/a
Ah, the reason I wandered into this discussion... I bought said VR550 a couple of years ago on ebay for about £35. Perfectly fine VCR but a bit short on manual controls. There is no way of twiddling the tracking (it's automatically done for you apparently) but mine is now struggling to play our old tapes . It will record and play new footage OK but I don't really need it for that (have DVD-RAM & HDD). We want it to play our old stuff (esp. the old wedding vid).
I rang a company that had serviced our old VCR and they said they didn't do VCRs any more as it wasn't economic to repair them (bet they'll change their tune when you can't buy a VCR any more and people still want to watch their tapes).
Anyway - I was wondering about opening it up and having a poke. In the words of Jezza Clarkson, "How hard can it be?"
Anyone know what is likely to cause the tape to look like the tracking's gone to buggery and which bit I need to hit?
ta
Nick
Old 04-12-2008, 11:36 PM   #10
JayCee's Avatar
30,379, Level: 42
Points: 30,379, Level: 42 Points: 30,379, Level: 42 Points: 30,379, Level: 42
Activity: 37.2%
Activity: 37.2% Activity: 37.2% Activity: 37.2%
Thanks: Gave 168, Got 1,187
Rubbish...didn't you read your user manual in play or slow motion mode press the P+ and P- buttons to manually adjust the tracking.
They're correct...spare parts are either unobtainable or cost the earth...add a labour charge and you're better off buying a new VCR (a Funai probably) or a VCR-DVD.
Yes, it's probably a worn pinch roller...available from here @ £25 + p&p
Old 05-12-2008, 2:45 PM   #11
phoenicks_uk
Posts: n/a
Ah, well, yes I did but: a) I forgot to mention that because: b) it doesn't make any damn difference to the picture.
Blimey, it's barely seen any action! I think I'll just open it up and see if there's anything that needs cleaning or tightening. If that doesn't sort it then I'm probably going to have to save up for a DVD-RAM freeview VHS combi system.
Cheers!
Nick
Old 05-12-2008, 8:23 PM   #12
4,755, Level: 16
Points: 4,755, Level: 16 Points: 4,755, Level: 16 Points: 4,755, Level: 16
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 16, Got 258
It might be sufficient to just clean the heads - there are two fixed heads which stand vertical, like very wide versions of what you see in an audio cassette recorder/player. One of these is the erase head, and the other has mono audio at one end, and LP/SP/control at the other. And of course there are the many heads on the rotating drum, which are very delicate.
Old 05-06-2009, 11:11 AM   #13
3,860, Level: 14
Points: 3,860, Level: 14 Points: 3,860, Level: 14 Points: 3,860, Level: 14
Martin.
I have one thats works great,not been used much,your for a small fee
Old 05-06-2009, 11:52 AM   #14
Senior Moderator
80,796, Level: 69
Points: 80,796, Level: 69 Points: 80,796, Level: 69 Points: 80,796, Level: 69
Activity: 40.9%
Activity: 40.9% Activity: 40.9% Activity: 40.9%
Thanks: Gave 1,218, Got 3,008
Please note that any negotiations and arrangements for sale items must be conducted through the forum classified section, which has it's own set of rules, and which you can find here.
Old 19-01-2010, 2:09 PM   #15
2,057, Level: 10
Points: 2,057, Level: 10 Points: 2,057, Level: 10 Points: 2,057, Level: 10
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 2, Got 9
I realise this thread is old, but I'd like to know what it's like now. I need a VCR to accompany my Blu Ray system so I can still play my Doctor Who videos that I've had for years (big collection). I don't need any fancy features, just something reliable that works and will still work with modern tv setups.
I know Ebay sell a lot but I know nothing about what's recent or a good price. DO people know what the most recent VCR's are from decent brands like Panasonic or LG?
Old 19-01-2010, 2:29 PM   #16
28,191, Level: 40
Points: 28,191, Level: 40 Points: 28,191, Level: 40 Points: 28,191, Level: 40
Activity: 89.2%
Activity: 89.2% Activity: 89.2% Activity: 89.2%
Thanks: Gave 39, Got 2,263
I think your best bet is a dvd/vcr combo which you can still find new.
Old 19-01-2010, 2:42 PM   #17
Senior Moderator
80,796, Level: 69
Activity: 40.9%
As Graham alludes above, the only two still currently available are a DVDR/ VCR combo the EZ48 Details here or the expensive DVDR/ VCR/ HDD combo : EX98V Details here.
I can't recommend anything from LG
Old 19-01-2010, 3:50 PM   #18
4,755, Level: 16
Activity: 6.1%
There are Toshiba DVD/VCR and DVD/HDD/VCR too.
Also there's the VCR 2 PC which as well as connecting to PC via USB can behave as a VHS player. Expensive though for that purpose.
Old 20-01-2010, 3:27 PM   #19
10,764, Level: 24
Points: 10,764, Level: 24 Points: 10,764, Level: 24 Points: 10,764, Level: 24
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 12, Got 354
If you just need a cheap VCR for playing/recording VHS tapes try the British Heart Foundation Furniture & Electrical stores.
The Rochdale store had around 20 second-hand VCRs including at least one Panasonic model. Prices around £20/£30 or even less.
British Heart Foundation - Furniture and Electrical
Powered by
 Latest popular product prices
Sagemcom UK DTR 67250T ECO DVB-T...
2 prices from
 £99.97 Click to show/hide the offers
2 prices from
Logik L250STB11 DVB-T Twin Tuner...
3 prices from
 £109.99 Click to show/hide the offers
3 prices from
Goodmans GBD123DTR DVB-T 320GB
1 price
 £114.39 Click to show/hide the offers
1 price
Sagemcom UK DTR 67320T DVB-T Twi...
3 prices from
 £119.60 Click to show/hide the offers
3 prices from
 Updated February 12th at 5:30pm. Prices include delivery.
