| Dazzle DVD recorder connection problem
I want to use my Dazzle DVD recorder to record/burn VHS tapes from video recorder to DVD on my new laptop (HP pavilion DV7-1110 ED with Vista SP1).
On the back of my vid.recorder (Sony SLV-SE80VC2) there are 2 Scart sockets: LINE 1 (TV) with an arrow in & out and DECODER LINE 3-IN with an arrow in.
I also have a switchable Scart, which I plugged into LINE 1 (TV); on the switchable Scart I make sure the switch is pointed to the arrow "going out" to Dazzle DVD recorder.
I went through the whole procedure of selecting the source: options: video composite, PAL, Dazzle DVC 100, VHS record - the burner etc.; format the DVD first, but as soon as I started the vid. recorder and hit "Record" I got an error message "Burn error".
I've tried switching the arrow on the switchable Scart to point to the other direction ("going in"), even plugged my switchable Scart into the DECODER LINE 3-IN, plugged in an S-video cable in the switchable Scart (adjusted the options into S-video) - nothing helps, I keep getting the "Burn error" message.
Although I can see that my vid. recorder is playing, the window on the upper right is black.
Does someone know what's going on and what I did wrong ?
BTW: the laptop burner is doing fine, I've burned some DVD's.
Thanks for any help on this matter.
