Originally Posted by barboofa Hi I bought my humax 93OOT about 3 months ago. Really pleased with it. But today when I turned it on it started to load then went blank. It just keeps reloading, comes on for about 10 seconds then goes blank. Anyone experienced this problem? Anyone know what to do to fix it? Thanks |
Try switching it off and removing the aerial. Now switch on if it boots OK do a factory reset. Switch off put aerial back in switch on repeat factory reset and restore your channel list and preferences.
Assuming this works check your channel list for channels numbered 800 or over. If you have these please post again for more info
