| Re: So confused!! Please help
Just to check.....aside from any other cables and connections you
- removed the aerial cable from the back of the TV and put it into the Thomson.
- and then you added another aerial cable running from the RF output of the Thomson and into the aerial socket of the TV. And the TV no longer receives as well as it did.
Correct? If yes, then first try this. Pull BOTH the aerial cables out of the Thomson and plug the one cable directly into the other. Re-test the TV.
IF the TV misbehaves, then the second (new) aerial cable is suspect. Try another one.
IF the TV does not misbehave then the Thomson box is suspect. The problem may be as described by grahamlthompson; I don't know if the Thomson has an RF modulator.
If not then, depending on your signal strength you may be able to solve it by splitting the aerial feed (with a Y adaptor) at the wall and running one branch to the Thomson and the other straight to the TV. If your signal isn't that good, you may need a powered splitter.
