| PVR out to analogue
Hi, hope someone can help.
I have a Sony RDR-HD870 PVR which plays recordings fine by scart cable to our main TV. I also want to be able to play recordings to a TV in the kitchen about 7 metres away. At the moment I have a direct aerial connection coming to a socket behind the main TV which I split, one to the PVR and one to the kitchen TV, that all works fine too.
I want to be able to output PVR recordings onto this cable to send to the other TV but I'm not sure how to do it. As far as I can tell, none of the analogue outputs on the PVR send the playback. obviously there's the scart and hdmi output but the analogue out just forwards the standard aerial signal if there's an analogue in (which there isn't) and the digital out seems to forward on the aerial signal from the digital in.
I could of course be missing something but it seems to me there's no obvious way to send a UHF or digital signal to the second TV. Can anyone help?
edit: I've already bought a splitter cable with a switch so only the PVR playback or aerial signal is sent at once.
Thanks.
Jon.
