Originally Posted by Bellboy21 I am not qualified to say.
TV connected to Funai TB3-N by scart .
I would guess that TV outputs nothing to Funai Recorder.
Funai Recorder recieves input from Aerial and Freesat (By scart)
TV connected to VHS by scart .
TV outputs to VHS Recorder.
VHS Recorder recieves input from Aerial
For anyone interested, I attach a plan which I prepared for the Panasonic Helpdesk. |
A diagram makes it so much easier.
If you have a cheap freeview box heres how to connect it to be able to record independently
Take Aerial In out of Funai and put it in Aerial In on new Freeview box. Connect Freeview Aerial (RF) out to the Funai aerial in. (Male to female coax)
If your funai HDD can record using RGB then the connection you are using is severely restricting the quality of the recording as the Foxsat vcr scart only has composite and s video. To get RGB you need to use the foxsat TV scart.
If you however use the scart switching facility to get the Foxsat to automatically start the funai recording you may lose this by using the Foxsat TV scart)
Assuming this capability the audio/video connections of the freeview box would be Foxsat TV scart to Freeview VCR scart. Freeview TV scart to Funai scart (not labelled on your diagram) funai scart to TV AV3 (check av3 on the tv has rgb capability some don't so if only scart 1 is rgb swap AV1 with AV3 (If AV2 is rgb compliant move the freeview box to av2). In any case you need to make sure that your highest quality analogue source (Freeview/Freesat) has a RGB connection.
Assuming the dvd recorder will record from RGB then one word of warning it won't work on BBC HD as the scart RGB SD outputs are disabled by the broadcaster so you will only be able to record composite (which is your current arrangement anyway)
If you dont want the extra freeview box simply move the foxsat connection from the vcr scart to the tv scart (subject to the above restriction) and ensure that the funai is connected to a rgb capable scart on the TV
