Humax 9200TBX 320GB
Old 28-03-2008, 9:54 AM   #1
AV-Nan
Posts: n/a
Humax 9200TBX 320GB
Hi everyone
After instruction from my grandson I have purchased this unit.
Overall I'm happy with this unit.
I can record 2 channels at the same time and still watch a 3rd if it is on the same multiplex of one of the other used channels - very impressive!
Series Link is really good, not as advanced as Sky's, but makes things much easier.
I don't like the TV guide side on view, as I prefer the guide to show one channel at a time with all the programmes on show, as it can get a bit confusing showing multiple channels and only displaying part of the programmes name.
Picture quality is good, but find my Netgem I-Player to be sharper, both connected using RGB via Flagship Profigold scart leads.
The remote I loved at first until I found that to use alot of the features you have to pull down the fascia to reveal the tiny hidden buttons.
Pausing and rewinding live TV is a sinch, no complaints.
Has anyone tried connecting an MP3 player to the unit or is the unit only compatible with a PC with the supplied software?
Is the unit compatible with a keyboard as the search takes a while with the remote and eventually I can see the remote suffering from wear and tear quite sharpish.
Can anyone enlighten me about the power function for an aerial, the manual states if I have an active indoor aerial, well I have a regular aerial so I turned this off, but I wonder if it acts as a signal booster?? I didn't want to experiment in case I damage the unit.
How does the commercial skip work?
Thanks AV-Nan (Jessie)
Old 28-03-2008, 3:23 PM   #2
5,550, Level: 17
Points: 5,550, Level: 17 Points: 5,550, Level: 17 Points: 5,550, Level: 17
Thanks: Gave 1, Got 185
Re: Humax 9200TBX 320GB
Do yourself a favour and remove the cover permanently. ALL the useful buttons are under it.
PC only though there is 3rd party software that usually works better. Forget the MP3 support, its flaky anyway.
Is the unit compatible with a keyboard.
No.
It feeds power on the aerial cable to power masthead amplifiers. Only enable it if you have one. Most wall plug signal amps have their own power.
Hit the skip buttons, it just jumps a fixed time (30s forward,7 back by default) - they're tiny ones under the panel you've hopefully now removed
AV-Nan (29-03-2008)
Old 29-03-2008, 7:48 AM   #3
AV-Nan
Posts: n/a
The guide view is still bugging me is there different view selections I have missed??
Old 30-03-2008, 1:12 PM   #4
5,550, Level: 17
Given the usual request is to see more channels shown on the EPG I doubt you'll ever see a single channel view added. Frankly I'll be disgusted if they waste time on something like that while serious bugs remain unfixed.
canvey (08-04-2008)
Powered by
 Latest popular product prices
Sagemcom UK DTR 67250T ECO DVB-T...
2 prices from
 £99.97 Click to show/hide the offers
2 prices from
Logik L250STB11 DVB-T Twin Tuner...
3 prices from
 £109.99 Click to show/hide the offers
3 prices from
Goodmans GBD123DTR DVB-T 320GB
1 price
 £114.39 Click to show/hide the offers
1 price
Sagemcom UK DTR 67320T DVB-T Twi...
3 prices from
 £119.60 Click to show/hide the offers
3 prices from
 Updated February 12th at 5:30pm. Prices include delivery.
