Originally Posted by dmx0007 it just starts recording blank tape |
It may be locked in "One Touch Record" mode.
Try pressing the record button repeatedly until it stops...I know what I'm saying sounds daft but try it.
Most modern VCRs have this "OTR" mode whereby if you press the record button once it will record until you manually press stop or switch it off...on OTR mode if you press the record button twice it will record for 30 mins and then switch off, if you press it 3 times it will record for an hour...and so on in 30 min increments.
The trouble with this OTR mode on some models is that it locks the machine in record mode and won't allow you to stop it...it can only be stopped by pressing the OTR record button repeatedly and looking at the display until it cycles back to 0 mins...you should then be able to stop and eject the tape.
Other than that...I think the eeprom IC in the VCR may be corrupt and it won't be worthwhile repairing.
