Originally Posted by Gavtech I still have five working S-VHS machines, [ Panasonics: FS90, FS200, HS950, and two HS830's ] albeit it is a bit of struggle keeping the older ones working... It's worth it though.... plus I feel obligated to do so. |
I used to have a Panasonic FS100. The PSU was a bit unreliable, but after blanket replacement of capacitors and a few Zener diodes, it worked flawlessly right up until I sold it. I agree, the build quality was fantastic, even had a proper audio stage with high grade audio capacitors on it (Elna Silmic/ Panasonic Purism caps).
I still have a Philips VR813 which uses the same G-Deck Panasonic mechanism as the FS100. I find it more suitable for time-shifting and day-to-day use rather than editing. It even has VPT, Subtitle recording, 5 page memory Fastext, and RGB output built in. Not bad for something manufactured in 1991.
