Originally Posted by galleonslap Sorry if this has been asked before, but I couldn't find it on a search. Do any of the Freeview PVRs allow a programme to be recorded from the start, if the record button is pressed manually after the programme has already started? Thanks for any info. |
The Humax PVR9200 continuously buffers the channel being viewed (from the return from the last interruption, ie. another channel, playback, or menu).
If you wish to record a missed start on the buffered channel, you have to rewind the buffer to that point before pressing record. Wherever it starts, the end time, displayed onscreen, is from the EPG so check and modify if you want recording to end later - or of course you can end manually before then.
I believe the Topfield can do what you ask more simply.
