| Re: Missed start of programme but still record with Humax?
Yes, hit play (or pause), scroll back to the start time with the cursor pad, OK then hit record and it should record from there to the programme end. You can hit record again to change the end time.
Be aware that all instant recordings take priority over timers, timers that overlap can be lost and it can cascade through following timers so you'll need to check and manually work round failed ones. Maybe some year Humax will make the machine try to start recordings more than once instead of giving up instantly.
Reason: added hit OK....doh!
