Akai Pro GX4 - HF
Old 27-08-2012, 4:08 PM   #1
Thanks: Gave 4, Got 0
Akai Pro GX4 - HF
A neighbour has one of these vcr's but no manual - does anyone know where I could look at one? When a video plays there is at the bottom right of the screen a small horizontal box which counts down the video playing. Is it possible to stop this and if so how do you do it?
Old 29-08-2012, 2:20 PM   #2
JayCee's Avatar
Thanks: Gave 254, Got 1,398
If this is present on all tapes it must be generated by the VCRs on-screen graphics and there should be a button or option within the VCRs menu to turn it off.
Can you upload a picture of the remote?
Old 29-08-2012, 2:40 PM   #3
unfortunately the original remote died and has been replaced with a generic general one. Using the front buttons I cannot find any way of adjusting anything on this vcr. It produces a great picture but the box is annoying and it is present on all tapes.
Old 29-08-2012, 3:06 PM   #4
JayCee's Avatar
Therein lies your problem, features like on-screen graphics choices are normally only accessed through the menu and very rarely on a dedicated button on the machine.
Some generic remotes have access to secondary functions but you would need to study the remote's user manual to see if yours has.
Old 29-08-2012, 4:59 PM   #5
thanks looks like he is stuck with it - cheers
