AV2HDR - sound problems
Old 22-07-2012, 8:43 AM   #1
Thanks: Gave 1, Got 0
For the last few months I have been having a problem with the sound transfer from my pen drive to my Foxsat HDR. The sound comes and goes with in seconds. I have tested the pendrive transfer on the computer and its fine, its only when I have transferred it to the foxsat this happens. Here is a copy from D-town that I converted from their site to a vob file.
General
Complete name : E:\Video\DVD\Episode 120 D-Town TV.vob
Format : MPEG-PS
File size : 419 MiB
Duration : 21mn 14s
Overall bit rate : 2 758 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 21mn 14s
Bit rate mode : Variable
Bit rate : 2 511 Kbps
Nominal bit rate : 9 800 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.242
Stream size : 382 MiB (91%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Duration : 21mn 14s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Stream size : 29.2 MiB (7%)
Here is the details from the .ts file
General
Complete name : G:\Episode 120 D-Town TV_20120722_0836.ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 469 MiB
Duration : 21mn 11s
Overall bit rate : 3 086 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Duration : 21mn 14s
Bit rate : 2 763 Kbps
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.266
Stream size : 420 MiB (90%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 21mn 14s
Bit rate : 192 Kbps
Stream size : 29.2 MiB (6%)
I am at a loss as to what to do. I don't want to waste disks as I know DVD would be better and resolve the problem. So any ideas please?
Old 06-08-2012, 1:56 PM   #2
Okay, it seems I have had no responses here. I am sure someone here has an idea, so could anyone advice me as I am being driven mad by poor sound. The only free software that will convert to .vob files for me with accuracy and ability to change the spec is FormatFactory.
