Recording problems with my PVR
Old 09-07-2012, 3:46 PM   #1
Hi All, I am having problems with my Marks and SpencerPVR 80 GB, it will record the channel you are watching and will play back fine BUT if I am watching say BBC1 and record something on say ITV 1 it records but when you play it back it jumps all over the place and the words don't match the mouths. This seems to be happening only if I am watching a different channel to the channel I am recording. Any help would be much appreciated.
Many thanks
Old 13-07-2012, 1:28 PM   #2
JayCee's Avatar
Thanks: Gave 253, Got 1,398
Have you tried rebooting the PVR as in removing the mains power then restoring it/switching back on?
If that doesn't help try retuning the PVR as in 1st time installation.
Old 13-07-2012, 4:17 PM   #3
Hello and thank you for taking the time to reply, yes I did a re-boot on it but did not try the first time installation, so will give that a go and see what we get.
Thank you
Old 19-07-2012, 11:36 PM   #4
Problems recording on pvr
Hi Jaycee, I tried the first time installation but unfortunately it made no difference. When I record itv the recording jumps about a lot but on bbc it only jumps a few times in 30 minutes. I tried recording on itv, channel 4, and channel 5 and the recording jumps and the picture freezes but on bbc1 and bbc2 it only happens a few times in 30 minutes. Any more ideas for me to try before I invest in a new model.
Regards
Old 20-07-2012, 12:33 AM   #5
brian badonde's Avatar
Thanks: Gave 9, Got 11
Hi Mistyscamp, if the box is still under warranty/guarantee I'd return it, doesn't sound right. If your budget can stretch to it go for a Humax pvr £150ish, alternatively check out e-bay for maybe a Logik 160gb/250gb freeview pvr, they can be had for £30-£40 unused (acc to seller)in auction with a 12-month warranty from a specific seller- x-traders. Apologies moderators, if I'm not meant to mention specific sellers/sites.
