Freesat, PVR, with blueray player?
Old 24-06-2012, 1:37 PM   #1
Limited Member
Thanks: Gave 2, Got 0
I all, i am new to this part of AV. I am looking for a Free-sat, PVR, with blue-ray player, not recorder.
I want to dump Sky as we use very few of the channels, but would still like to be able to record and time shift programs.
Having a blue-ray player included will remove at least one box.
I do require good quality pic's as I am driving a B&O tv.
Any help would be much appreciated.
Peter.
Old 24-06-2012, 2:34 PM   #2
Illustrious Member
Thanks: Gave 145, Got 2,869
Afaik the only Freesat box ever made with blu-ray was the Panasonic range which also recorded.
Zylog (27-06-2012)
Old 24-06-2012, 5:15 PM   #3
Thanks: Gave 30, Got 314
OP will have to satisfy with including recordable BD (Panasonic) or two boxes. The latter would be preferable to including a BD player in a PVR.
Samsung make Freeview PVRs with built-in BD player. Their PVRs are not well thought of and being able to choose a PVR from one manufacturer and a separate BD player is advisable.
Zylog (27-06-2012)
Old 25-06-2012, 11:48 AM   #4
Limited Member
Thank you both for your replies, it would seem that I am not going to be able to reduce the number of boxes in my system. Oh well! I will have to put up with it.
I have now looked at the Panasonic and i would never use blueray recording so that makes it a very expensive proposition.
From the research I have undertaken it would appear that one of the Humax range would be the best choice?
Any comments would be welcome.
Old 03-07-2012, 8:49 AM   #5
Thanks: Gave 114, Got 80
The Panasonic IS an expensive proposition. However, as Panasonic have discontinued their Freesat PVR range (and only relatively recently) you might be able to get a clearance bargain.
Clem
Old 03-07-2012, 5:12 PM   #6
spinaltap's Avatar
Thanks: Gave 1, Got 218
You don't specify which B&O television you are using, but my local B&O dealer ran a Humax Foxsat from a separate room to feed a BeoVision 7-40.
Clearly, I don't know your budget - but regarding a suitable Bluray player for your B&O, a pre-owned BeoCenter2 might be an option - LifeStyle AV | Pre-owned Bang & Olufsen you can trust
