Originally Posted by Steven Collis I have just bought this player/recorder and am pretty happy with it. I do have one problem, and that is that after playing any sort of optical disk, the unit appears to freeze and only a reboot will fix it. I have looked on the Samsung support web site and searched elsewhere with no joy.
The unit updated its firmware straight away, so I should have the latest version. Does anyone know what I'm doing wrong? |
Mine has this problem too. The manual states that you should be able to press 'exit' whilst playing a bluray or dvd and it will take you back to TV. This is what I've found with mine:
* playing a DVD, press stop, it returns to home screen. Then pressing any buttons cause it to freeze (the icons stop moving)
* playing a DVD, press exit or return - nothing happens.
* playing a bluray, press exit or return - nothing happens.
* playing a bluray, press stop, it returns to home and continues to function.
* playing a bluray, press pause, then press home - it returns to home - BUT it will only play the bluray from the beginning, it won't return to where it was up to.
What it means is that you can't pause your disk, watch a tv show and come back to it.
I'm going to swap it tonight and see if I've got a bad one or if it's bad for everyone. Samsung phone support were unhelpful.
Can anyone confirm they are NOT having this problem?
