I bought the 320gb model off ebay, second hand for £90. After having a Digihome 80Gb pvr for a number of years (what a fantastic user friendly piece of software that had!), i can't believe how badly this performs, even with the 3.1.1 software upgrade...... Correct me if I'm wrong but.......
1. You can't watch half a recording, then come back to it later.
2. You can't start watching halfway in (see point 1) you have to skip until you get to where you were previously, if you can remember.
3. Box takes so long to power on that I left it on whilst bathing only to find it had locked when I returned. On pulling the plug and resetting, because a recording had started, it says it is recording but won't let me do anything else, EPG, change channel, nothing!
4. Everytime I select the library the programmes start playing automatically in the preview window (is this a selectable setting??) and when I choose ok to view full screen, it starts from the beginning again, very, very annoying.
5,6,7,8,9,10 Can't be bothered lol
Have I just got a crap second-hand one or is this typical????
Either way its going back and I will go back to my SD Digihome and wait for a better product to hit the market, fingers crossed!!!!
