| problems with SVR-HDT500 box
Further post from the Sony Forum which doesnt sound great as this indicates the problems are being caused by the box trying to download every type of software update out there??
Written on 08-Jul-2011 16:46
Sony SVR HDT500
I have tried all of the workarounds recommended in previous posts, but they do not work.
Just returned from my local Sony Centre, where I am pleased to say that the box played up just as it does at home. After much head-scratching and checking that my box has the same firmware level as those in the shop, Sony Technical was contacted. The information provided was thus:-
- Sony have not recently issued any firmware updates to the SVR HDT500
- It is believed that the problem is caused by the Linux Operating System in the box attempting to execute firmware upgrades from other manufacturers (i.e. not ignoring them), which is causing the problems being described in this topic. As such turning Auto Update off will have no effect, as this will only prevent Sony firmware updates being applied.
- Sony are working on a fix (firmware upgrade?), with no estimate on availability.
It has been recommended that as updates occur overnight, that the box be unplugged from the mains and from the aerial. (None of the Sony Centre's boxes on display have the problem as they are turned off overnight, but hard luck if you want to record a programme that is broadcast then.)
In addition, if the above is done and a Repair Disk performed then all subsequent recordings made in the daytime or evening should playback ok. Any problematic recordings made prior to the instigation of the above process may never playback properly.
For those of you who are getting replacement boxes, Good Luck! Sony Centre would not replace my 3 month old box as they say it would have to go for repair for whenever a fix is available.
