Originally Posted by apuckey Hi
I'm looking for advice & help !
Last year I purchased a Humax Foxsat HD receiver, unfortunately I was stupid enough not to purchase the PVR model !
Hence, without spending £250 for the next PVR model - is there a PVR that can record from an external input - scart ?? as my freesat box has a 'VCR' scart socket.
For example can the Humax PVR-9150T or Humax PVR 9300TB record from an external input
any help appreciated
regards
Alan |
Hi Alan - In his response, Gavtech probably meant to say DVD/HDD recorder - though theoretically a DVD recorder would suffice, in practice a recorder with a hard disc is far more flexible & satisfactory.
By the way, if you do get a DVD or DVD/HDD recorder, don't connect from the VCR Scart socket on the Humax but from the TV Scart to the input Scart (usually AV2) on the recorder, which will give you good quality RGB output - then from the recorder Scart out (usually AV1) to a Scart input on the TV.
