Pace Twin Playback Question
Old 29-02-2004, 2:20 PM   #1
7,178, Level: 20
Points: 7,178, Level: 20 Points: 7,178, Level: 20 Points: 7,178, Level: 20
Thanks: Gave 17, Got 1
Is it possible to playback recorded programmes on TV2/VCR?
I have the TWIN set-up in Room 1 with the TV SCART output connected to the TV in Room 1.
I have the TV2/VCR SCART output connected to another TV in Room 2. I can send remote control signal from this room to the TWIN box.
I want to access the following functions from Room 2, and view on the TV connected to TV2/VCR scart.
1. Access and playback recorded programmes.
2. Access the EPG so I can set up recordings
Is this possible, or can it be only done in Room 1?
Old 29-02-2004, 2:35 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
You will need an IR repeater system to control the twin.
Old 29-02-2004, 4:00 PM   #3
7,178, Level: 20
Like it says already in the post that I can already send remote control signals to the TWIN from Room 2, in other words I do have control of the TWIN!!
Old 29-02-2004, 4:07 PM   #4
Assured Advertiser
63,997, Level: 61
ERM so what exactly do you need to know. Of course the second scart will output everything the first one will!
Old 29-02-2004, 4:09 PM   #5
7,178, Level: 20
You obviously don't have a Pace TWIN!!!
Old 29-02-2004, 4:18 PM   #6
Assured Advertiser
63,997, Level: 61
Actually i have 5 one on demo and 4 in stock so what exactly are you trying to do the guide and recording list is available on the RF output (should be available on AV2 output as well)
Old 29-02-2004, 5:30 PM   #7
7,178, Level: 20
I've been playing with the TWIN but I cannot get the guide, recording list or library to be available on the TV2/VCR (AV2) output? The only thing I can control or operate is the changing of channels.
I have the TV2/VCR scart connected to a second room through cat5 connection with IR feedback.
Is what I'm trying to do possible?
Old 29-02-2004, 5:45 PM   #8
Assured Advertiser
63,997, Level: 61
I havent tried using the VCR scart to acess the guide I will have a play at work tomorrow if i get time. presuming that you wont use the box in both rooms at the same time why not distribute AV1 to both locations?
Old 01-03-2004, 10:07 AM   #9
idhutt
Posts: n/a
Milanlad
Unfortunately what you want to do is not possible. Tuner 2 (which appears on AV2) does not have text or EPG and I do not believe that it can also playback record programs. These are however available from the modulator if set to Main tuner so you could use AV2 for viewing a seperate show (or that currently being recorded) and UHF for TV guide and replays.
Not sure what twin horneydragon has got, but its certainly not the one made by Pace
-Ian
Old 01-03-2004, 10:18 AM   #10
5,822, Level: 18
Points: 5,822, Level: 18 Points: 5,822, Level: 18 Points: 5,822, Level: 18
Thanks: Gave 2, Got 8
I would try to use the 'archive' function on the library screen.
This sends the output to scart2, but you will not be able to see what you are doing to set it up unless you can view the primary scart signal.
Chris
Old 01-03-2004, 11:33 AM   #11
Assured Advertiser
63,997, Level: 61
I dont use it much. I new there was a way to send recordings to the AV2. a 2 way scart distbutor would be best that way you get AV1 in both rooms and full control
Powered by
 Latest popular product prices
Sagemcom UK DTR 67250T ECO DVB-T...
2 prices from
 £99.97 Click to show/hide the offers
2 prices from
Logik L250STB11 DVB-T Twin Tuner...
3 prices from
 £109.99 Click to show/hide the offers
3 prices from
Goodmans GBD123DTR DVB-T 320GB
1 price
 £114.39 Click to show/hide the offers
1 price
Sagemcom UK DTR 67320T DVB-T Twi...
3 prices from
 £119.60 Click to show/hide the offers
3 prices from
 Updated February 12th at 4:30pm. Prices include delivery.
