Originally posted by JohnWH My assumpion is that use of the Tivo requires me to by two decoders boxes so I can watch and record at the same time. |
That's true - but the thing is, with a TiVo, you can watch a pre-recorded program while recording another one! So, if like most TiVo owners, you end up watching mostly (or only!) recorded shows, then you'll never really need 2 tuners
Originally posted by JohnWH I'm also assuming that the tivo doesn't record the digital bit stream, instead having convert and recompress the analogue signal, with all the inherent quality loss that implies. |
I agree with MarkE19 and others - the quality loss is minimal. I have a Panasonic 36PD30 and the difference between the "live" feed and a "Best" quality recording is almost unnoticeable.
In fact, I don't bother using "Best" for most recordings - as the quality of the original source doesn't often warrant the extra disk space used. Most channels on Sky are not transmitted at a high enough bitrate to start with - so all you "gain" by using Best quality, is the ability to see the edges on the original broadcast artefacts a bit clearer
Originally posted by JohnWH Maybe its time to just move to sky. |
By all means, move to Sky - but don't be fooled by Murdoch into assuming that Sky+ is a decent alternative to a TiVo.
True, you can record the original artefacts, exactly, and get DD5.1 (sometimes) - but
Sky+ is NOT a proper PVR. It doesn't have half the features (even now) that all TiVos have had for years - like proper Season Passes (that persist beyond a reboot, and from one season to the next), Wishlists (record all programmes with you favourite actor), intelligent conflict resolution, bug-free self-upgrading of the HDD (to 2x300gb if you want!), supreme hackability - and a lively UK
forum of people dedicated to getting the best out of their TiVos.
