Originally Posted by ht0242 Hi Graham Sorry I have no idea if it has an internal modulator. The box I’ve got is a Logik LPVR 168 and on the basis it wasn’t very expensive I’m going to guess that it hasn’t. (can you enlighten me?) So the questions which follow are Where do you get external modulators? What extra bits do you add to the magic eye? Could you give me an idea as to the cost please? Thanks in advance M |
To continue to use a magic eye you need two things
1 a 9V power supply for the eye
2 A gadget that turns the remote control signals coming down the coax back into Infra Red (This has the advantage that it can transmit remote control info to pretty well any remote box using a magic eye)
Both are available from here (may be other equivalents as well)
Buy Now
I see others have pointed you at external modulators. If you have a vcr you can usually use it's modulator by connecting the pvr vcr scart to the pvr vcr scart and selecting the vcr scart as the input on the vcr.
