Hi all,
I am tearing my hair out at this network problem.
#1 ps3 connected to router as DMZ
#2 ps3 connected to router with port forwards.
#2 ps3 disconnects every 10 to 15 minutes from the psn and whatever game online.
How can i get round this issue? Has anyone had this problem?
I can't enable UPNP on the router because it will conflict the ports being used by ps3 #1
Because ps3 #2 cannot use the same port or port range of that game or service
for the record and info:
ISP: Virgin Media 50mb
Router: Netgear (same control panel as most models)
2 ps3s - 1 internet connection (1 ip) - 1 router
All wired.
i have set up manual settings via ps3 / auto / etc
still having the issues...
ANY HELP PLEASEE!!!!!!!!!!!
Has anyone else got 2 ps3s connected to 1 router and got it runnin' fine?
basically the data for port : xxxx doesnt know what ip to send it to, from the router.
even tho its all set up - its bloody wierd!
example:
sign on ps3 with both ps3s = fine
Internet = fine
Gaming like cod, battlefield and gta etc = #2 ps3 being disconnected all the time.
When i look at the logs i can see ps3 #2 trying to use the same ports.
Upnp does that aswell.
its just the second ps3 playing up... has anyone got any ideas at all?
any help or routers that may work good - or anyone actually got 2 ps3s up and running on a router?
Normal router as in pc etc works fine, just this 2nd ps3 we got.. im lost now tbh.
