vga connection help?
Old 24-02-2009, 1:39 PM   #1
2,658, Level: 12
Points: 2,658, Level: 12 Points: 2,658, Level: 12 Points: 2,658, Level: 12
Thanks: Gave 3, Got 3
Hi there wondering if anyone can help! was wondering if there is any way of connecting the ps3 from hdmi to vga? as cheap as possible?
thanks Jon
Old 24-02-2009, 6:17 PM   #2
2,658, Level: 12
Re: vga connection help?
help????
Old 24-02-2009, 6:55 PM   #3
7,534, Level: 20
Points: 7,534, Level: 20 Points: 7,534, Level: 20 Points: 7,534, Level: 20
Thanks: Gave 278, Got 201
HDMI Male to DVI-D Dual Link Video Monitor Cable, HDMI Dual Link Cable - Techfoc - Techfocus
you could try these there quite cheap
http://www.amazon.co.uk/Cabling4Less.../dp/B000FII810
and this
Old 24-02-2009, 7:05 PM   #4
7,534, Level: 20
i may be wrong more info here
VGA to HDMI
Old 25-02-2009, 11:25 AM   #5
2,658, Level: 12
cheers for your help, appreciate it
