farcry areas?
Old 21-12-2008, 12:39 PM   #1
2,331, Level: 11
Points: 2,331, Level: 11 Points: 2,331, Level: 11 Points: 2,331, Level: 11
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 13, Got 11
farcry areas?
I have heard about different areas in home speciffically for games like far cry2. I cant find them tho. Are they US or jap only?
Old 21-12-2008, 12:50 PM   #2
Illustrious Member
47,248, Level: 53
Points: 47,248, Level: 53 Points: 47,248, Level: 53 Points: 47,248, Level: 53
Activity: 47.3%
Activity: 47.3% Activity: 47.3% Activity: 47.3%
Thanks: Gave 395, Got 933
Re: farcry areas?
They're in the US Home for sure and not the European one. If you have a US account then you can you jump right into the US Home although it may require you to re-download the areas i the UK one when you use that again. It happened to me
Old 08-01-2009, 10:26 PM   #3
Illustrious Member
jonneymendoza's Avatar
41,668, Level: 49
Points: 41,668, Level: 49 Points: 41,668, Level: 49 Points: 41,668, Level: 49
Activity: 60.8%
Activity: 60.8% Activity: 60.8% Activity: 60.8%
Thanks: Gave 1,659, Got 968
Re: farcry areas?
so the far cry 2 space is really in the US version of Home?
Old 09-01-2009, 12:32 AM   #4
Illustrious Member
47,248, Level: 53
Activity: 47.3%
Re: farcry areas?
For now anyway. It's coming the same time as the Uncharted one but they need to work on them before releasing them here.
When i tried the US Versions, they are very small and should hold no more than 10 people at a time yet it's still taking 50 people (plus 14 reserved spaces) and it makes it unusable and everyone walking through each other so i hope that's getting fixed 1st
Old 09-01-2009, 11:10 AM   #5
9,331, Level: 23
Points: 9,331, Level: 23 Points: 9,331, Level: 23 Points: 9,331, Level: 23
Thanks: Gave 162, Got 266
Re: farcry areas?
Is there anything special in the FarCry area?
Old 09-01-2009, 11:51 AM   #6
11,496, Level: 25
Points: 11,496, Level: 25 Points: 11,496, Level: 25 Points: 11,496, Level: 25
Activity: 34.5%
Activity: 34.5% Activity: 34.5% Activity: 34.5%
Thanks: Gave 181, Got 338
Re: farcry areas?
No, I thought it was a bit of a disappointment to be honest. The upstairs room felt creepy as there's no ambient noise (first time I was there I thought my amp had broke!). The station area is okay I guess - the outside looks pretty realistic (as it's a dump!).
There's a couple of security doors on the Uncharted area where you need to put in a special code to unlock them - I couldn't be bothered to explore though. The bar isn't really big enough for 50 people at once - and it's full of Americans.
Old 15-01-2009, 11:05 AM   #7
6,275, Level: 18
Points: 6,275, Level: 18 Points: 6,275, Level: 18 Points: 6,275, Level: 18
Thanks: Gave 207, Got 124
Re: farcry areas?
Do we have an ETA or anything for FarCry 2/Uncharted GameSpaces in Europe? I've got a US account, but I'm quite attached to my avatar (and Pac-Man T-shirt!) in EU Home, I don't think I can be bothered to set it all up again for US!
Old 24-01-2009, 2:46 PM   #8
2,654, Level: 12
Points: 2,654, Level: 12 Points: 2,654, Level: 12 Points: 2,654, Level: 12
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 88, Got 12
Re: farcry areas?
These are in the EU one now. Went on last night.
Nothing in there really, unless I missed something.
AL
Old 24-01-2009, 7:09 PM   #9
3,863, Level: 14
Points: 3,863, Level: 14 Points: 3,863, Level: 14 Points: 3,863, Level: 14
Thanks: Gave 52, Got 9
Re: farcry areas?
It is a bit of a disapointment. I would not bother downloading it and i will not be going there again.
Old 24-01-2009, 7:48 PM   #10
2,801, Level: 12
Points: 2,801, Level: 12 Points: 2,801, Level: 12 Points: 2,801, Level: 12
Thanks: Gave 51, Got 49
Re: farcry areas?
If you go to your saved game data you can copy the HOME saved data to all your other accoounts eg US account and then your avatar will have the same clothes and body/hair etc etc
Ed the Penguin (26-01-2009)
Old 24-01-2009, 9:00 PM   #11
Illustrious Member
47,248, Level: 53
Activity: 47.3%
Re: farcry areas?
I did that but found that every time i go on each region of Home (US/Europe) i had to keep re-downloading the areas
Old 26-01-2009, 8:45 AM   #12
5,127, Level: 16
Points: 5,127, Level: 16 Points: 5,127, Level: 16 Points: 5,127, Level: 16
Thanks: Gave 3, Got 0
Re: farcry areas?
I've searched everywhere but can't find the FarCry area. Where abouts is it?
Bob
Old 26-01-2009, 10:42 AM   #13
Illustrious Member
47,248, Level: 53
Activity: 47.3%
Re: farcry areas?
Press start and get your PDA up. Go to the locations tab and it will appear along with the red bull Area and all the previous areas
bobboulby (26-01-2009)
Old 26-01-2009, 12:17 PM   #14
6,275, Level: 18
Re: farcry areas?
All within the XMB?! I'll have to take a look at that then.
Old 26-01-2009, 2:05 PM   #15
1,955, Level: 10
Points: 1,955, Level: 10 Points: 1,955, Level: 10 Points: 1,955, Level: 10
Thanks: Gave 13, Got 24
Re: farcry areas?
You need to delete the unwanted settings first - steps here
http://www.avforums.com/forums/ps3-h...ml#post8364474
regards
potnoodles
