| Re: UK PS3 (80 gig) - will it work in US ?
Games are region free , movies are not , so your UK PS3 wont play region 1 ( or american region ) movies. Thats an operating software thing.
The hardware itself is not region coded , and power on any PS3 Ive seen is from 100 - 240 v , so all you would need to do would be to go to radioshack or similar and buy a power lead.
The only possible issue hardware wise would be if you were using an SD TV , in which case you would run into the PAL vs NTSC thing.... but thats easily avoided by using a flat screen.
