PSP Demos - "This contetent cannot be downloaded"
Old 20-04-2008, 8:37 PM   #1
4,385, Level: 15
Points: 4,385, Level: 15 Points: 4,385, Level: 15 Points: 4,385, Level: 15
Thanks: Gave 108, Got 66
So I'm trying to download some demoes from the PS store to transfer to my PSP but once I've clicked download and it's comes up with the final download screen it tells me "The content cannot be downloaded"
This is for the Wipeout Pulse, Socom: TS and Logan's Shadow.
This is doubly annoying as a mate downloaded them on his PS3 and copied them to my PSP. However, he'd done that on his us account. Later he downloaded some other stuff on his UK account and when he transfered these ones over to my PSP the PS3 had to reasign the PSP to the UK account and rendered the previous demos unusable. I thought it wouldn't matter as I could just download it all again via my PS3 and reasign my PSP to that.
Anyone got any advise as to why this is happening and what I can do about it?
PS. I can download patapon ok.
Old 21-04-2008, 10:18 AM   #2
kBm kBm is online now
kBm's Avatar
13,717, Level: 28
Points: 13,717, Level: 28 Points: 13,717, Level: 28 Points: 13,717, Level: 28
Activity: 12.5%
Activity: 12.5% Activity: 12.5% Activity: 12.5%
Thanks: Gave 474, Got 766
Re: PSP Demos - "This contetent cannot be downloaded"
You could always try downloading via the PS store on a PC. You need to download the 'download manager' and connect your PSP.
Easy to do and acts as a back up for when things don't work!
HTH
McNab (21-04-2008)
Old 21-04-2008, 11:39 AM   #3
4,385, Level: 15
I didn't realise you could do that. I'll give it a go. Ta.
