Help with wireless using BEUNLIMITED and speedtouch modem
Old 04-05-2007, 1:54 PM   #1
-Hitman-'s Avatar
9,197, Level: 22
Points: 9,197, Level: 22 Points: 9,197, Level: 22 Points: 9,197, Level: 22
Activity: 3.5%
Activity: 3.5% Activity: 3.5% Activity: 3.5%
Thanks: Gave 79, Got 140
I am trying to configure my BE online speedtouch modem wirelessly with the PS3.
I have searched and found the modem and entered the ssid and WPA key but when i try the connection test it connects to the modem then tries to exchange the network key and ends up timing out and giving a failed status.
At one point the PS3 got to the assigning ip address stage but again this timed out and gave the failed status.
Any one help who has the same setup?
thanks.
Old 06-05-2007, 12:28 PM   #2
3,357, Level: 13
Points: 3,357, Level: 13 Points: 3,357, Level: 13 Points: 3,357, Level: 13
Re: Help with wireless using BEUNLIMITED and speedtouch modem
I had the same problem, the key is case sensitive so try entering it again with capitals(or not) and it should work. Hope this helps.
-Hitman- (07-05-2007)
Old 07-05-2007, 9:01 PM   #3
-Hitman-'s Avatar
9,197, Level: 22
Activity: 3.5%
Worked a treat!
Cheers.
Old 08-05-2007, 7:37 PM   #4
4,441, Level: 15
Points: 4,441, Level: 15 Points: 4,441, Level: 15 Points: 4,441, Level: 15
Thanks: Gave 3, Got 1
btw..since im a fellow BE and PS3 user..i thought i would ask what do you lot think of using the PS3 online with BE?
So far using the PS3 online has been excellent! PSN downloads are MEGA fast, online playability is seamless and having played PS2 games online i think BE is probably one of the best isp's for online gaming!
Old 11-05-2007, 2:34 PM   #5
4,697, Level: 16
Points: 4,697, Level: 16 Points: 4,697, Level: 16 Points: 4,697, Level: 16
Activity: 5.3%
Activity: 5.3% Activity: 5.3% Activity: 5.3%
Thanks: Gave 181, Got 253
I'm a BE user too - and download speeds are great
Shaz
Old 17-05-2007, 12:19 AM   #6
4,965, Level: 16
Points: 4,965, Level: 16 Points: 4,965, Level: 16 Points: 4,965, Level: 16
Thanks: Gave 69, Got 153
I am also a BE user and the downloads have been very fast, so fast that I have started to download anything on the US store and my PS3 drive is starting to get full now.
Old 17-05-2007, 11:13 AM   #7
3,616, Level: 14
Points: 3,616, Level: 14 Points: 3,616, Level: 14 Points: 3,616, Level: 14
Thanks: Gave 22, Got 31
naqv,
please can you let me know your settings to access ps3 on bethere, i keep getting a dns failure.
thanks mate
Old 04-06-2007, 2:39 PM   #8
KingConker
Posts: n/a
Yes - but have you got streaming working with Be - wirelessly?
