Moving to Brazil
Old 19-10-2009, 10:18 PM   #1
3,855, Level: 14
Points: 3,855, Level: 14 Points: 3,855, Level: 14 Points: 3,855, Level: 14
Moving to Brazil
I will move from UK to Brazil.
Of course I will have to get a new ISP with a new email account.
Will I be able to retain my existing UK PS3 Account?
Will I lose the credit that I have on the PS3 Store?
apologies if this has been asked before, but I could not find any reference to it.
Old 08-11-2009, 8:06 AM   #2
43,182, Level: 50
Points: 43,182, Level: 50 Points: 43,182, Level: 50 Points: 43,182, Level: 50
Activity: 48.5%
Activity: 48.5% Activity: 48.5% Activity: 48.5%
Thanks: Gave 3,072, Got 3,157
Re: Moving to Brazil
As long as you can log into your UK account you should be fine on all fronts. I used to play regularily with Tetlee the Wii moderator. At the time he was based in Argentina and apart from a little lag every now and then you wouldn't have know he was 1000s miles away. I should be clear that this was using an XBOX 360 but I don't see why you would have any probs with your PS3. You are taking your UK console with you aren't you ?
