Psn Home ? dont work
Old 17-10-2009, 10:31 PM   #1
3,777, Level: 14
Points: 3,777, Level: 14 Points: 3,777, Level: 14 Points: 3,777, Level: 14
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 13, Got 4
Thumbs down Psn Home ? dont work
Thought would have look at Home but it said i needed an update to version 1.3 so i did that but now locks up the PS3 on the initialising screen, have to power PS3 off to recover
anyone else have this problem
Old 17-10-2009, 10:47 PM   #2
Conspicuous Member
24,796, Level: 38
Points: 24,796, Level: 38 Points: 24,796, Level: 38 Points: 24,796, Level: 38
Activity: 22.8%
Activity: 22.8% Activity: 22.8% Activity: 22.8%
Thanks: Gave 355, Got 1,104
Re: Psn Home ? dont work
Yep. I didnt really try home, and I set an account up just before the update. A couple days later I came back and got the update, now it just locks up so I havent bothered with it.
Old 18-10-2009, 7:53 PM   #3
2,399, Level: 11
Points: 2,399, Level: 11 Points: 2,399, Level: 11 Points: 2,399, Level: 11
Thanks: Gave 13, Got 26
Did you try uninstalling home and reinstalling it as I mentioned in my thread on the issue? Press triangle when home icon is selected on the XMB and delete it, then reinstall by selecting icon again and pressing X.
Old 31-12-2009, 4:17 PM   #4
4,792, Level: 16
Points: 4,792, Level: 16 Points: 4,792, Level: 16 Points: 4,792, Level: 16
Thanks: Gave 6, Got 2
I have the same problem, I have deleted and reinstalled about 5 or 6 times but it still locks up, any other ideas ?
Old 31-12-2009, 5:06 PM   #5
2,399, Level: 11
Try the following, should sort it:
If you still experience difficulties logging in after deleting and reinstalling the client, we suggest that you delete the Apartment save data for the last apartment that you visited. Deleting this save data will erase the furniture layout for the apartment selected, but it will not otherwise affect your inventory or cause you to lose any of your items. Select “Save Data Utility” under the “Game” column on the XMB. The name of the Apartment is displayed under the date of the save data.
Old 31-12-2009, 5:17 PM   #6
4,792, Level: 16
Thanks for the help but I have never been able to get any further so dont have a saved apartment, there was 13kb save file which I also deleted but still no dice I`m afraid.
Old 31-12-2009, 5:28 PM   #7
2,399, Level: 11
What version of Home are you on? V1.32 is meant to fix the freezing problem with previous version.
Old 31-12-2009, 5:40 PM   #8
4,792, Level: 16
It is version 1.32 and I believe the ps3 firmware is 3.15
Old 31-12-2009, 5:51 PM   #9
2,399, Level: 11
Hmmm....... did you check that the file you deleted was the only one? Worth making sure there are no other data files for home in the data saves.
Running out of ideas fast
Old 31-12-2009, 6:09 PM   #10
4,792, Level: 16
I couldnt find any other files to delete, looking around the net if the delete trick doesent fix it then there doesent appear to be any other way, will just have to wait for another update I suppose.
Old 31-12-2009, 6:22 PM   #11
2,399, Level: 11
One last question.... did you check under game data, home can store stuff there also.
Sorry, can't help further, lets hope next update does help you out.
Old 31-12-2009, 7:01 PM   #12
4,792, Level: 16
Thanks again brunog for your help, I did check under game data.
Old 18-02-2010, 11:00 AM   #13
Dean's Avatar
7,798, Level: 21
Points: 7,798, Level: 21 Points: 7,798, Level: 21 Points: 7,798, Level: 21
Thanks: Gave 50, Got 55
Exclamation
I'd like to check something with you guys, I can get on Home but not very often. I have a suspicion that my wireless connection is hampering the connection to the PSN. How many of you guys can get on Home frequently without connection/parse errors with a wireless connection? I might try using a wired connection but this means more hassle installing cables etc. Thanks in advance.
Old 22-02-2010, 12:51 PM   #14
2,551, Level: 11
Points: 2,551, Level: 11 Points: 2,551, Level: 11 Points: 2,551, Level: 11
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 66, Got 22
Dean just use homeplugs mate they are superb minimal wires
Old 19-03-2010, 10:44 PM   #15
4,792, Level: 16
My PS3 home works ok now, I tried it the other day and it updated and loaded, the kids like it.
Old 21-03-2010, 3:40 PM   #16
Illustrious Member
47,248, Level: 53
Points: 47,248, Level: 53 Points: 47,248, Level: 53 Points: 47,248, Level: 53
Activity: 47.3%
Activity: 47.3% Activity: 47.3% Activity: 47.3%
Thanks: Gave 396, Got 933
Since the update, its certainly worth using now. This is what it should have been like when it originally went public.
