Originally Posted by Kim-Jong_ILL I orginally had O2 mobile broadband and my ps3 online gaming worked fine with it barely ever lagging and all that. I got rid of that though and got 3 mobile broadband as it was cheaper and I had more gb and the speed was the same but for whatever reason the lag with this leaves ps3 online gaming impossible as its always lagging and won't connect to some games.... so why the problem with the ps3 network? |
Surely, given your PS3 worked fine previously on O2, the problem is not with "the PS3 network" but something to do with your 3 Mobile config, their network or some interaction between them.
- Firstly i'd ask how you connect to the 3 Mobile network, if its by a wireless connection, then switch your PS3's wireless off and use an ethernet cable.
- Does 3 Mobile have any sort of capping, limits or anti-peer-to-peer clauses? It might be they're limiting when it detects your PS3.
- Have you opened up all ports needed for the PSN? It might be 3 Mobile has some needed ports closed by default.
And this assumes when you say the 360 is fine, you're trying both at the same time, and not the 360 at 0400 hours in the morning, and the PS3 at 2000 hours at night
